Question about Apple MacBook Air
Keys all mixed up keyboard
Keyboard all mixed up: q is now a and vice versa; ; is now m and vice versa etc Tried changing keyboard preference; SMC restart; shutting down etc don t know where period is Very difficult to type
  • 4 Answers
System Preferences > Keyboard > Input Sources
Check to see correct keyboard is present in the sidebar to the left.
If you're dealing with multiple keyboard layouts, tick "Show input menu in menu bar" at the bottom of this same preference menu. Then check the input menu in the menu bar to see if correct keyboard is selected.
Let me know if this helps!
Posted on Nov 20, 2013
Testimonial: "I have done all this and it did not work. I erased the language input (French Canadian), reinstalled it and still did not work. I switch to English Canadian and the keyboard worked but without the required accents for French. I shot down, restarted and re-selected French Canadian and the keys were back to their normal positions. I still fail to understand what created the mixed up in the first place."
  • dietern Nov 21, 2013
    Glad it worked out eventually! (even if for no apparent reason)
3 Suggested Answers
  • 35 Answers
SOURCE: when i type with the keyboard, it does not respond....
goto the apple store
Posted on Nov 30, 2008
acsmappel
  • 61 Answers
SOURCE: i key types io, k key types kl, , types ,. and vise versa
Fix your keyboard!
Posted on Aug 04, 2009
Macbook - lost left speaker, data, and camera. SMC reset either way didn't fix. Running external monitor which does work
You may have to reset the PRAM. Note: To print these instructions, open Help Viewer's Action pop-up menu (looks like a gear), then choose Print.
  1. Shut down your Mac.
  2. Locate the following keys on the keyboard: Option, Command (?), P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on your Mac.
  4. Immediately press and hold the Option-Command-P-R keys. You must press this key combination before the gray screen appears. Continue holding the keys down until your Mac restarts, and you hear the startup sound for the second time.
  5. Release the keys.
Resetting PRAM may change some system settings and preferences. Use System Preferences to restore your settings.
Happy 2015!
May 19, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tip
How to change your keyboard to french keyboard AZERTY or vice-versa?
Hello friends!
Sometimes we get laptop gifts from our relatives from abroad but the keys are AZERTY but types in as a QWERTY.
Well, go to control panel / Region & Language/ keyboards & languages(Tab)/ Change keyboards / Add (button) / choose french language /
You may need to expand to choose etc
Apply changes/ select the US keyboard to remove, apply changes & Restart
That's it!
on Mar 05, 2010 | Computers & Internet
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jun 06, 2012 | Apple MacBook Air
When I type I don't get the inverted comma as it gives me the "at " as in "@" and vice versa. Also the back slash key gives me hush instead and the shift-3 which is supposed to give me...
Be sure that your keyboard is configured properly. You should be able to check under the "Region and Language" area of control panel if you are in windows and select "Keyboards and Languages." Check that it is set as a US keyboard or that it's set to which keyboard type you are using.
May 02, 2011 | Toshiba 310CDT Keyboard
The keys are not synchronised properly. The @ key and the " are typing each others symbol. ie I have to press shift 2 to get the @ symbol and vice versa.
you are using a usa keyboard.
if you want to use the uk keyboard layout change the regional settings, go to languages and there is an option to change the keyboard.
uk keyboard will print " when pressing shift+2
Jan 12, 2010 | Dell 0Y3740 Keyboard
@ and " keys reversed
Go to "Control Panel>Local settings and language settings" , select the second tab "Languages" select the "Details...." button,
and change the US keyboard type to UK type or vice versa, whatever applies.
Jul 12, 2009 | Acer NSK8458AN Keyboard
Problem with keyboard, when i press key(@)it comes with(")and vice versa
1- click on start
2- click on setting
3- click on control panel
4- dobbol click on Regional and Language Options and select English (united kingdom) rather than USA, in customise and (united kingdom) in location.In Advanced, select English(united kingdom) in Language for non-Unicode programs and then click on ok or apply, some time it asked for windows cd like windows XP pro or home addition, depends on the system is installed. thanks
problem with keyboard, when i press key(@)it comes with (dobble quot " )and vice versa
Nov 14, 2008 | Computers & Internet
2 keys mixed up
Normally, this problem occurs if you language setting is different from your Keyboard language. All you need to do is change the setting of your keyboard language from Regional language settings from the control panel. Normally if your PC is pure US English, you should use English (US).
Hope this helps.
If it does please vote. Thanks!
May 01, 2008 | HP Pavilion dv8000z Notebook
Apple MacBook Air Logo
96 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
