Question about LG LWD3081ST Electric Double Oven
LG double oven shows f9 code in both ovens
I am worried I will not e able to cook thanksgiving dinner both LG double ovens showing F9 codes is this going to cost alot to fix
  • LG Master
  • 5,323 Answers
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Posted on May 18, 2015
2 Suggested Answers
  • 472 Answers
SOURCE: our oven is a lg
F7 ON THESE UNITS normally is either the control board itself or the touch pad... something to try is turn breaker off to unit... press on buttons firmly while off just to make sure none are stuck
after doing this reset breaker try again if it still gives a fault code f7 then you are going to have to replace control on unit.... good luck to you
Posted on Jan 12, 2011
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
Error code F9 shows on screen, oven is inoperable.
See service manual or contact manufacturer.
Nov 18, 2013 | Ovens
After is used the self-cleaning f9 error code
F9 code is a door latch error code. Either the latch motor or latch didn't get reset. Check the wiring to the latch motor and make sure everything is connected. Also try flipping the breaker and leaving it off for five or ten minutes, see if it might reset itself. If that doesn't work, you can have a latch motor gone bad, a harness issue, or possibly an electronic board that has shorted during the cleaning or operation programs.
Oct 24, 2013 | LG LWD3081ST Electric Double Oven
F9 error code
F9 problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
Sep 07, 2013 | LG LWD3081ST Electric Double Oven
F19 error code on lg double oven
had F19 error code on lower oven, F9 on upper. Pulled stove out and turned the regulator switch ON. Worked instantly. I thought I had the regulator on because the stovetop worked. The stovetop regulator is separate from the main regulator!!
Jun 22, 2011 | LG LWD3081ST Electric Double Oven
What does F9 mean
Failure to clean code
I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code.
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
LG LWD3081ST Electric Double Oven Logo
163 people viewed this question
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
