Question about Electric Circuit Breaker Kit for Furnace
The blower comes on but it won't ignite. there is a wire just hanging out, should it be plugged in somewhere. there are 3 possible places to plug it in to.
Changed the filter today and vacuumed the closet it is in. Now the blower comes on but it will not ignite. Could it be because there may be a wire disconnected.
  • 2,113 Answers
Not likely It is probably just coincidence that the igniter failed
Posted on Nov 28, 2013
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Why chevy blazer won t start after it rains ?
Its a possibility, that you can have a bad coil pack. start the vehicle, and spray the coils with a mist of water, from a spray bottle. If bad you see a spark. The coil pack is cracked somewhere.Meaning it was not water tight. It should be. Good-Day!
Sep 01, 2014 | 2003 Chevrolet Blazer
I just bought a Sears Craftsman snow blower,put gas and oil in it.Itried to pull the starter cord but it will not pull. I then tried the electric starter but it just grinded.Why won t it start?
Sounds like a serious flooding issue, perhaps due to having blower on its side, take out spark plug and place plastic bag over and try pulling over, be careful that it doesn't spark and ignite any fuel expelled out of cylinder.
if that is the case pull over several times blow off plug and try again, fuel might be trapped in muffler so be aware of spray, ignition.
If it doesn't pull over with the plug removed take it back as a valve might be sprung.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Not getting fire to plug,replaced ignition still no spark,echo pb-400e
With a good plug and a new switch there are a few remaining basic options. There is either a bad ignition coil or a bad wire or bad connection somewhere.
I hope this helps.
Jul 29, 2011 | Echo Inc. 25.4 CC Backpack Blower
STARTER HANGS UP WHEN STARTING..
Hi Local87, and the usual supects are:
1. Spark plugs are in bad condition, improper gap, partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged.
4. Loose wire connection at one of the battery terminals,coil, or plug between the Ignition Control Module.
5. Throttle controls not adjusted correctly.
6. Water or dirt in fuel system/tank
7. Water or dirt in carburator.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricking fuel flow.
10. Inrichner valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
For a possible prime suspect please visit the website below and good luck:
Harley Davidson Wiring Diagrams and Schematics
Jan 23, 2011 | 2000 Harley Davidson FLSTC Heritage...
Replace blower ,my fan stop blowing
Probably isn't you blower that is bad...they rarely die, check fuses, relays, and resistror, test motor before going thru the hassle of possibly replacing a good motor to find out it still won't blow. To check motor: unplug wire connector from the resistor, (located under right side of dash, should be two wires coming out of the housing), using a heavy guage wire, I'm not sure what color wires GM uses, but, if there is a black wire connect a piece of your wire to this side of the plug and running it to the negative battery post, the other side of the plug will need to be grounded with another piece of wire on some bare metal somewhere close to the plug.
Hope this helps!
Dec 14, 2009 | 1999 Chevrolet Suburban
Ihave a sears 2 cycle blower,vac and is not getting spark, is there anyway to check the igniter module--bill
remove the spark plug, plug it back into the plug wire place a screwdriver on the spark plug and the cylinder and pull the starter rope - if there is spark, you will see it on the plug [or you will feel it!]. if you have spark, put the plug back in and try to wiggle it side to side, if it rocks freeley, the cylinder bolts have come loose [a very common problem with these units]. the fix is pretty involved and not fun
Apr 04, 2009 | Craftsman 4 Cycle Blower/Vac
2001 kia sportage location a/c blower resistor
it is next to the blower fan up under the passengers side, I think it has 3 or 4 wires on the plug, just unscrew the 2 screws and disconnect the plug with the wires on it, www.kiatechinfo.com is a great place to get info on kia's, hope this helps, you need to know why the resister is going bad, this means a short somewhere, if the blower shorta out then the resister will get over heated, check the switch you ajust fan speed with to see if it is working right.
Apr 03, 2009 | 2001 Kia Sportage
Starting problems 260E
Many possible causes. Spark plugs, HT wires, Distributor cap or rotor, Stale fuel, Ignition coil or a fuel clog somewhere.
Sep 18, 2008 | 1990 Mercedes-Benz E-Class
Keeps mis-firing on cylinder #3 check engine light flashes and stays on car chugs on uphill slopes
check plugs wires for damage or just replace if you have replaced the #3 plug already if not replace it also
Aug 04, 2008 | 1999 Ford Taurus
Electric Circuit Breaker Kit for Furnace Logo
Top Electrical Supplies Experts
ashburton
Steve
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
