Question about LG 42LV5500 42 in. LCD TV
How to reset lg tv model 42LV5500 - LG 42LV5500 42 in. LCD TV
I have a LG 42LV5500-UA LED tv with a black screen. Power light comes on but that is it. Any ideas on what board needs to be replaced? right in the middle of a program went black.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 19, 2017 | LG Televison & Video
My LG 42LV5500 TV SET suddenly developed problem. All dead, black screen, no sound just power light. All PS voltages are correct.
I would agree with you on that. But it is your money. If the TV is old then replace it, if it is fairly new give it a try.
Jan 23, 2017 | LG Televison & Video
My LG 42LV5500 just stopped working. Totally black screen. On light is now a solid white.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.... . http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 02, 2017 | LG Televison & Video
LG TV 42LV5500 with vertical lines
T con Board or the LCD panel of the TV is faulty. You have to replace the Tcon Board to confirm where it is T con Or LCD panel.
Apr 15, 2016 | LG 42LV5500 42 in. LCD TV
LG 42LV5500-UA LED TV turns on, but has no picture or sound
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
Nov 04, 2015 | LG Televison & Video
Wired network is not set. Do you want to set wired network?
the tv should be plugged into a router, something that has a dhcp server. does your modem have a router built into it. without dhcp the smart function on the tv won't work. and that would take care that message, the tv just looking for internet access
Aug 23, 2015 | LG 42LV5500 42 in. LCD TV
My remotes won't work. Apparently the remote sensor is not working. This TV does not have a remote in plug on the back. Any ideas?
I have the same TV, but I don't understand what you mean about 'both remotes' or 'remote in plug on the back'. Do you mean a smart remote, the receiver for which connects via the USB?
The original remote uses the IR receiver on the TV. The smart remote only uses IR for the On/Off function; all other controls go via USB.
It is possible that the IR receiver in the TV has failed (I have replaced several on other devices). This is a cheap component, easily replaced by a competent solderer.
Jan 25, 2015 | LG 42LV5500 42 in. LCD TV
How do i do a factory reset?
Menu - Option - Factory Reset
Sep 27, 2014 | LG 42LV5500 42 in. LCD TV
Lg tv 42LV5500 reboots every 15 minutes
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 25, 2012 | Televison & Video
LG 42LV5500 42 in. LCD TV Logo
130 people viewed this question
Computer Repairing
Computer Repairing
