Channel A on my PMP 1280s is blown
I plugged an monitor into Output A while in bridge mode. Found out after that was a big mistake. Ok so I checked the fuses and they all still worked. None were blown. One fuse for power, one for effects and the other two im not sure what they do but i tested them and they work. They could be to the fans inside however the fans are not working either. Not sure if they only kick on when overheating. Im starting to think now that a transistor or two may have been blown. Is this a possibility? Also how would i test the transistors when they are sottered to the board and there is no evidence that anyhing was blown. I only know there is something blown because there was a pop sound and electrical burn smell while performing and no sound comes out of Output A now. Also is there a link to schematics so i know which transistors and circuits are for only Output A? Thanks in advance!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
This website appears to have diagram for it. You will have to register to log in. http://elektrotanya.com/?q=hu/content/how-change-site-language-english
May of been some other component burnt out. Only way is by test meter and testing. Quite possible transistor burnt out.
You should be able to test it in circuit for Short circuits.
If output transistors faulty make sure you check driver transistors as well. Hope some of that helps.
Posted on Nov 19, 2013
4 Suggested Answers
SOURCE: amp blows fuses
The fuses are there to protect the internals of the AMP.....
Please check that the correct fuses are installed......
if the incorrect ones are installed then a fire may develope...
There should be a manufacturers lable on the external chassis that details the fuses to use....
Fuses now days can be slow blow or fast blow....so the correct fuses must be used.....dont increase the fuse rating past the chassis panel label...but make sure they are correct...if they are correct then the amp needs a service to determine where the peak loadings to the power supply are originating from...
Some one may have installed incorrect fuses in the past...
Cheers from YUBEUT
Posted on Nov 03, 2007
  • 236 Answers
SOURCE: Samson Servo 170 protection circuit problem!
my friend resistors and diodes don't just go off your circuit without a real problem. those parts gave up because of shortage on your power section, i suggest that you check your power transistros first along with the diodes and resistors.
noisy transformers... hmmmm why is that making sound? the solution there is to dip the power transformer to a thick shellac varnish let it there for let's say an hour then let it dry for a day. then place it back in your unit and see if still sounds
Posted on Aug 13, 2008
SOURCE: no output to speakers mackie 808s power mixer
I can hardly even tell what you're talking about because you don't use any punctuation.
Posted on Dec 17, 2009
When I plug-in my vp1220f floor monitors in to the monitor mix on the pmp 2000 i get no sound or little sounds
If you are referring to the "monitor" output , this is a Pre-amp output which connects to a power amp or speakers that have built-in power amps. The Monitor output is a high impedance output. This output will not drive speakers directly.
Jun 02, 2014 | Behringer PMP-2000 Powered Mixer
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
Blown Output A on Europower PMP 1280s. what can be the problem?
Open emitter resistor, check impedance of speakers, possible u overload the system
Nov 14, 2013 | Audio Players & Recorders
Behringer europower pmp 1280s
You have a lot of company in the something stupid department. We've all done that. Plugging a monitor into output A probably grounded the bridge and blew a fuse. Those tiny fuses with white covers are ceramic but they can be tested the same as regular glass fuses. You can open up your amplifier and check continuity across each one. In case of a hard short, you may see some evidence of discoloration around the blown fuse.
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 | Music
I accidentally used the two outs (A & B) at turning on the pmp 5000 in the bridge mode. The mixer was normal during the first 10 minutes, then the mixer shut down and stop working, and now it doesn't...
Insufficient information ! Were you using a special cable used for bridged mode or used regular cables and just changed the slide switch to bridged mode? IF you had regular cables for A/B and just had the switch to the bridged mode NO DAMAGE WOULD RESULT. The bridged mode switch really only sets both amps to be driven from the same mixing buss as monaural. If you had a bridged cable and a plain one you would have overloaded one side amp. The amps have an "electronic" over current fuse and if you trip it you have to leave the power off for a minute or so and then re-power the amp. There is a HAZARD that I have written a tip in Fixya about PMP mixers. The sleeve of a 1/4 inch plug connected to side A is the HOT signal out of the amp as opposed to the B channel being the tip of the 1/4 inch plug...this assumes you might be using Speakon to 1/4 inch speaker cables. DO NOT under any circumstances use Speakon to 1/4 inch adapter cables as the barrel of the adapter female part on channel A is HOT to ground and you will pop the A amp.!!!! I am afraid that if you were using regular cables taht another failure occurred not related to the setting to bridged mode. The speaker leads for bridged mode are configured by the way the special bridged mode Speakon cable is wired... The slide switch only configures where the amps get there audio be it stereo busses or singly from one side. If after being off for a few minutes the amp still is totally dead, check the main power fuse which is alongside the power input connection in a plastic boat you pull out. IF THE FUSE IS BLOWN do NOT replace it as it will likely cause additional damage. Have unit repaired. There is a weak spot in these that results in arcing between layers of a multi-layer circuit board.
Apr 15, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have a pmp 3000 and a pmp 6000. what is the best wast to run out of the boards to the speakers? and is it better to run in mono?
No preference, just use mode that fits your venue. As far as system safety I would run in Stereo A/B rather than bridged mode.
Now please read my tip about PMP units on Fixya regarding a hazard if you convert the Speakon outputs at some point to 1/4 inch plugs. If you do this, please note that the SLEEVE, not the tip on channel A is HOT to ground and shorting this to ground will often fry channel A. Channel "B" the tip is the hot speaker lead. Thsi is done by Behringer to facilitate switching to bridged mode.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
No sound from the left side
Assuming your PAN controls are all at 12 o'clock, it looks like you have popped one side of the power amp. Please read my tip on here about the HAZARD on the "A" channel of PMP powered mixers. Essentailly, if you use Speakon to 1/4 inch cables or adapters the BARREL or the SLEEVE of channel "A" connector is the HOT side of the speaker and touch ground with it and goodbye Channel A side amp. They don't tell you about this in the manual. The tip of the plug is e cold side of the amp output UNLIKE channel B where the tip is the hot side. They do this to make it easy to implement "bridged mode".
Reepair of thes amps takes skill. This likely has the DPA300 module in it and you will find one side fried switching transistors and often a Zener diode. Sometimes the circuit board will have arced and be damaged.
Feb 28, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Is that ok to do mono on Thump TA1001
yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
Let me know if you need any more help,
Dave
Aug 08, 2008 | Thump TA1001 Car Audio Amplifier
91 people viewed this question
 Grubhead
Grubhead
