If you want a wired doorbell with video, Ring do one. For a simple wireless Bluetooth night vision, with speaker, doorbell push, none. The most basic with bells and whistles are twice the width and 50% taller. If you are going to invest in one, you may as well do it right. I just ordered one from wish.com
Ringhttps://ring.com > products > video-doorbell-wired
Ring's smallest and most affordable wired Video Doorbell yet! See visitors in HD video, get real-time motion alerts from the Ring App. Free Shipping on $49+ ... US$49.99 · ‎ In stock
WIREDhttps://www.wired.com > Gear > buying guides The Wyze Video Doorbell Pro (7/10, WIRED Recommends) is the first video doorbell I've tested under $100 that doesn't fail to alert or record some visits or ...
If your Honeywell plug-in doorbell won't stop ringing, there are a few things you can try to troubleshoot the issue: 1. Check the batteries: If your doorbell has batteries, make sure they are properly installed and have enough power. Replace them with new ones if needed. 2. Check the ring options: Press the ring option button with the music sign and cycle through the different ring options until you find one that stops the ringing. 3. Reset the doorbell: To reset the doorbell, unplug it from the wall outlet and wait for a few minutes before plugging it back in. This will allow the doorbell to reset and may solve the issue. 4. Check the chime settings: If your doorbell has multiple chime options, make sure the one that's causing the issue is not selected. You can cycle through the chime options using the settings button. 5. Contact customer support: If none of the above steps work, contact Honeywell customer support for further assistance. They may be able to provide additional troubleshooting steps or offer a replacement if the doorbell is defective.
See if there is sufficient voltage between the two wires using a voltmeter. Also check that there is voltage coming out of the doorbell transformer to the wires, and power from the regular AC line going into the transformer. Sometimes the transformer dies and it's time for a new doorbell, although in the old setups, the transformer was separate from the doorbell.
The cadence is different, but you can change all the other rings to a different tone. On a 76xx phone, press PROG and the CO button twice. Press your navigator button up (or down) until you hear the tone you like, then press enter to save.
