Question about Samsung Galaxy 551 Cell Phone
Touch screen the touchscreen does not respond. I have to open the phone to access the keyboard and use the arrows to navigate to which icon I need. Also can not answer incoming calls. This is terrible
Micromax a27 pattern attempts
Posted on Nov 19, 2013
4 Suggested Answers
SOURCE: I cannot answer a call using the touchscreen on my
THere Is A Setting Where You Can Make It Answer Using either THe Touch Screen, THe Dial Pad.Or Any Button
Posted on Aug 09, 2009
jerseymark
  • 358 Answers
SOURCE: The touchscreen on my Samsung Impression SGH-A877
Hi,you will have to replace the flex of the phone.
The flex make the touch pad to function,also the functioning of the number keys.
When you replace the flex the touch pad and the key will function again.
Thanks for using fixya.
Posted on Oct 01, 2010
fgrixti
  • 89 Answers
SOURCE: My Samsung SGH-a877 touch screen
Usually when touch screens don't work, it is due to water damage. You can bring your phone to your carrier's nearest store and ask someone that works there to check if your phone suffered water damage. They'll check the inside of your phone. If that's the case, you'll probably have to buy a new one. If you're insured this shouldnt be TOO expensive. But if you bring it to the store and it's NOT water damage (perhaps a software issue), they should replace the phone for free!
Hope this helped
Please rate my solution!
- Frankie
Posted on May 06, 2011
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
Hi i have a dell inspiron laptop unfortunately my touch pad got locked, please help me to unlock it thanks
Hello
Press the Windows icon key on your keyboard, and hold it down until the "Start" menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl" and "Esc" at the same time.
Press "C," then arrow down to "Control Panel" and press "Enter."
Navigate to "Mouse" with your arrow keys, and press "Enter" to open up the mouse control dialog box. Then, press "Alt" and "F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device settings" or "Touchpad" or the similar option on your system, and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights, and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
Apr 17, 2011 | Dell Inspiron 1545 Notebook
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Dropped samsung jet touch screen not responding,
The touchscreen connector has come loose. It's a small flatcable which connects the digitizer (touch screen) with the pcb on the back of the screen. It's repairable, however you need to disassemble the complete phone. A great disassembly guide can be found here: http://www.formymobile.co.uk/jetdisassembly.php Good luck! :)
May 28, 2010 | Samsung Jet S8000 Cell Phone
My HTC Touch HD touchscreen does not allow to input pin
Hi Matt, Is your touchscreen not responding? Try put your sim to other phone and disabble pin.
May 12, 2009 | HTC Touch HD Smartphone
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
Samsung Galaxy 551 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
