Question about Nordic Track Nordictrack T 8.0 Treadmill Console Pt307492 Ets899410
I had a surge in the house while using the treadmill. I shut it off then on. It goes to the hifgest speed then stops
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Please RUN the Software calibration for easy diagnostic and fix it. Read the instruction manual, and follow the steps.
God bless you
Posted on Nov 19, 2013
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: reebok 5500C - when turn on treadmill and increase
hi,
Replase the IGBT on the aluminium heat sink. this problem will be solved. Adde the photo of IGBT .
ajin_g_5.jpg ok
Posted on Mar 08, 2011
Power surging
sounds like the treadmill is drawing too many amps. try using a larger surge protector.
Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
Proform 785SS was in flooded basement.
Controller faulty...replace controller....you can get used parts at www.usedtreadmillrepairparts.com
Dec 28, 2013 | Exercise & Fitness
Jumps to the highest speed setting when started
Run please the software calibration, ready your instru manual and follow the steps for diagnostic and fix it.
God bless you
Nov 19, 2013 | Nordic Track NordicTrack T 8.0 Treadmill
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Display shows LS1low speed code
hai ,
pls check 12pin communication cable and speed sensor wire also
Dec 13, 2011 | RTO Sole F80 Treadmill
I have an everlast folding treadmill and the machine starts fine but then it speeds up and and stops and the display say E1. I tried adjusting the belt but to no avail. Please help. Thank you.
if your everlast speeds up all of a sudden it is your speed controller and this is useally caused by you not lubricating under the walking belt, a dry belt will cause friction which causes the motor to labor harder and then over time your motor will over heat and cause speed problems,
or buy pluging your power cord directly into your out let the surges with cause your controlle board to fail over time u must plug the power cord into a 15amp surge protector with min 500 jouls and 1 plug at all times,
you should always have a anti static mat under the whole treadmill if your treadmill is on carpet static can de magnatize your motor, and static will be pulled into the treadmill
so when u step on your treadmill u become charged with static so every time you touch your computer console you are causing little charges to your console which over time cause the computer to male fuction,
also watch out for useing cheap exstention cords they will cause major damage to your treadmills electronics and motor they can not carry the proper voltage from the outlet into your treadmill so this will daMAGE YOUR TREADMILL ALWAYS USE A HEAVEY OUT DOOR THICK EXSTENTION CORD make sure it is 15 amps and a heavy gage and no longer the 10-15ft
the longer the exstention cord the more power you loose
Tim Ramsay
Lubeatread Inc
lubeatread@sympatico.ca
16 feb 2011
this goes with all treadmills
Jan 27, 2011 | Sport & Outdoor - Others
My treadmill starts out just fine on a three mile hr. setting, but after about two min. the speed goes to 0 and the treadmill stops.
When the speed goes to 0, does the motor stop or can you still hear the motor running like normal?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 09, 2010 | Epic View 550 Treadmill
My Proform XP 650e Treadmill starts and suddenly stops. The belt turns real fast then it suddenly shuts down like the power was turned off.
This condition is when the treadmill goes to full speed as soon as you power up the treadmill. Typically when this occurs, it is an indication of a short circuit in the motor controller.
Jun 28, 2010 | Proform XP Weight Loss 620 Treadmill
My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Jan 23, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
Treadmill motor cuts out on speeds 10km/hr or more within a very short time incline or not at lower speeds no problems Cheers
Sounds like you've never lubricated the belt. This has caused frequent overheating issues so now at higher speeds, the motor control board overheats and shuts down.
You'll have to first loosen the belt, then lubricate it. After words, tighten the belt again, if at all possible, don't tighten it as much as it was before, as overtightened belts are often a contributing factor.
Then calibrate the treadmill, make sure you are using a surge supressor and you hould be good for a while.
Nov 01, 2009 | York Exercise & Fitness
Nordic Track Nordictrack T 8.0 Treadmill Console Pt307492 Ets899410 Logo
43 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
