Question about Dryers
Whirlpool LER6620PQ1 won't heat. I've had the heating element checked with an ohms meter and it gets a reading in both places. Coils aren't broken but look slightly blackened on the outside. Blower works, just no heat. What's a girl to do?!
    New Friend:
  • 14 Answers
Check the high temperature switch. If it is bad it won't let any voltage go to the element...
Posted on Nov 19, 2013
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool LER5636EZ3 dryer won't heat
hi If it reads 0 hms yes thats te problem Thanks the appliance doc
Posted on Sep 12, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool dryer won't heat
hi. thanks for letting me answer.the only part that was not mentioned. is the timer contacs Y & R . the heat contacts in the heating circuit. thanks
Posted on Sep 29, 2008
  • 351 Answers
SOURCE: Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Posted on Apr 19, 2009
heatman101
  • 43501 Answers
SOURCE: I have a whirlpool dryer,
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
How do I check to see if the oven is working properly?
You need to
A/ FIRST TURN THE OVEN OFF COMPLETELY.
B/ Get access to the terminals ( usually at the back of the cooker)
C/ Disconnect the wiring from the terminals, there will be 2, 1 on each terminal.
D/ Obtain a multimeter and set it to ohms
E/ Place 1 lead on each of the terminals and check the reading in ohms on the scale.
F/ No reading on the meter indicates the heating element has gone open circuit or blown.
G/ Obtain make/serial number/type. Order a replacement from a supplier of heating elements.
Sep 15, 2014 | Whirlpool GMC305PDS Electric Double Oven
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Not getting heat
Hello there mark and welcome to fixya
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, you will need to test it for continuity it should read 000 on the meter if good and a 001 or a 1 means bad ok the meter needs to be set at the lowest ohms scale . Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 17, 2011 | Whirlpool Dryers
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    LER7646 won't heat. I checked the resistance of the heating element (12ohms). The high limit thermostat reads 0 ohms and the thermal cutout read open on the ohm-meter. I replaced the thermal cutout and...
    A typical reason the thermal cutoff would go out so quickly is because of a poor airflow so the heat is being built up in the dryer instead of being vented out.
    What to check is for a blocked/restricted vent,lint built up in the blower housing that is restricting the airflow& or a broken blower wheel that isn't moving the air from the dryer.
    GENE
    Sep 05, 2011 | Whirlpool LER5636P Electric Dryer
    Unit is GQ3RA-036K with H3HK010H-01B heat strip. I have checked continuity on the coils and the temperature switch both check fine. I have measure the voltage on the red and black wires connected to the...
    you need to ohm out the heater elements. Its the ohm reading that will give you insight as to whether or not the coils are bad.
    When ohming out the elements, be sure to tag and disconnect all electrical leads to the meter...otherwise you will get a false reading.
    If the elements read OL, then they are bad. Also, check to see what the voltage is to the heaters. Ensure the voltage supplied corresponds with the unit dataplate.
    Jan 09, 2010 | Heating & Cooling
    How to determine if a heating element in a dryer is bad?
    With the power off, touch the two meter leads to either side of the element on the ohms scale, lowest setting (R x 1) or if digital 0-600 ohms. If element is goo, it should read around 12 -15 ohms depending on the wattage rating. If you wiggle it and you get a reading , it's damaged and needs to be replaced. It's broken in two and just touching.
    Aug 01, 2009 | Dryers
    Not heating up
    check the wiring to the heating element and ensure all the connections are tight and there are no burned wires. The heating element should be continious with no breaks.
    ohms should peg the meter if everything is good.
    Jun 02, 2009 | Dryers
    Dryer won't heat.
    Hi, THe heating element is located in the back of your dryer. UNPLUG the dryer. Remove the back panel and you will see the element on the right hand side. If you have an ohms meter, check continuity on all the thermostats and the element. If any of them have no continuity, it will need replaced. Please let me know if I can assist you further.
    Thanks
    Vic
    May 16, 2009 | Whirlpool LER5636P Electric Dryer
    Kitchenaid superba dryer won't heat Where is the heater fuse located?
    Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
    A - Things that could stop a electric dryer from heating:
    - house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
    A ohm meter test for these parts is here.
    Q - My gas dryer will not heat, what could stop my dryer from heating?
    A - Things that could stop a gas dryer from heating:
    - glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
    A page for checking gas dryers is here.
    Meter testing and usage tips.
    1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
    2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
    3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
    4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
    5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
    6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
    7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
    But darn it, I don't have a Ohm Meter....
    To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
    To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
    To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
    How to take apart information for GE style dryers
    How to take apart information for Inglis - Whirlpool - Kenmore dryers
    How to take apart information for Maytag dryers
    How to take apart information for Frigidaire and White Westinghouse
    How to take apart information for Admiral, Norge, Magic Chef and Crosley
    Mar 30, 2009 | KitchenAid Dryers
    Dryers Logo
    62 people viewed this question
    Top Dryers Experts
