Question about Nordic Track NordicTrack T 8.0 Treadmill
Jumps to the highest speed setting when started
There was a surge in the house
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Run please the software calibration, ready your instru manual and follow the steps for diagnostic and fix it.
God bless you
Posted on Nov 19, 2013
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Jumps to highest speed then stops when started
RUN the software calibration for easy diagnostic and fix it. Follow the steps in your instr. manual. or download from www.fitness.manualsonline.com
God bless you
Nov 19, 2013 | Nordic Track NordicTrack T 8.0 Treadmill
2009 Ford Mustang GT/CS; Wiper's inop. Motor and switch are brand new. Circuit 2026 (constant 12v+) is good, circuit 2025 (ign 12v+) has no power. Fuses for both circuits are good, and I have 12v+ positive...
Could it go through a body control module some where? In most cases Key,to switch,then to motor. All the speed and park should be built in the motor/gear box.
Oct 17, 2013 | Ford Mustang Cars & Trucks
My 1998 jeep grand cherokee surges at cruising speeds. also jumps in secound gear.
It sounds like you either have an Electrical Issue with the PCM or your Band is slipping and you are looking at a rebuild sometime soon.
Apr 09, 2013 | 1998 Jeep Grand Cherokee
My dryer will not turn but the light inside works. we had apower surge from downed wires and several items in my house wereburned out from the surge what in the dryer could have been damaged by the surge...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Kenmore Dryers
Truck shifts out of gear at 50 to 60 miles an hour jumps in and out of overdrive at those speeds
check the tps ( throttle position sensor ). a bad tps causes transmission shift issues, bucking, jerking, idle surging, engine cutoff, hesitation on take off, surge while cruising down highway. am not saying this does the trick, but it is a good starting point. good-day !
Jul 19, 2011 | 1996 Dodge Ram
I had a power surge or loss while away come back and my mother board or chip or something happened but the front side bus jumped speed from 533 to 840
go to BIOS and in Advanced Settings or Chipset Settings there should be a Load Optimal Settings that will restore clock speed down to 533MHZ
Jan 11, 2011 | Computers & Internet
2001 Ranger XLT heat and air conditioning only work on high speed
there is a flapor motor that is controled by vacume, check for leaks in the vacume lines on the engine.
Sep 30, 2009 | 2000 Ford Ranger SuperCab
Blower only works in highest setting. Once in a while the fan starts working on the other speeds as well. There is a funny burnt smell coming out of the vents when the highest speed is chosen.
Unfortunately you have to point fingers at the Chrysler engineers that though this one up. It is almost a direct shot from your defrost vents to your blower housing. All of the dirt, sand, dust & junk that has gone down those vent holes over the past 12 years is now built up at the base of your blower and causing the blades and shaft to bind. The burnt smell is from the plastic blades rubbing through the ****. You need to dismantle the blower housing give it a good cleaning, go ahead and replace the motor and the blades, they're fairly cheap and put screens over your defrost vent holes.
May 09, 2009 | 1997 Chrysler Town & Country
Speedometer has quit working.
The voltage of your car's battery and the surge from the other car's battery when you jumped might have been enough to blow the fuse on the electronic speed sensor, or the sensor itself, try locating the fuse box and search for anything to do with sensors or so, if there's nothing wrong there it's the sensor itself, and you'll need to take it to a workshop.
Mar 09, 2009 | 2002 Chrysler Town & Country
Nordic Track NordicTrack T 8.0 Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
