Question about Gigabyte Computers & Internet
Keyboard doesn't work after boot
After installing the windows 8.1 update my USB keyboard no longer works after the boot up. It works fine until I get into windows. I am able to access the bios menu... Also, I have a ps2 keyboard that works after the boot. I'm guessing it's somewhere in the bios setting... but I am unsure what I should enable/disable. All of the usb options seem to be enabled that I can tell.
  • Scott
    Scott Nov 19, 2013
    Also, I'm pretty sure that it is not a driver issue as the keyboard worked fine before the update and I double checked after the update. My motherboard model is gigabyte GA-990XA-UD3
  • 4 Answers
Try booting up with the ps2 keyboard.Once in Win 8.1, unplug ps2 and plug in usb keyboard. See if windows will recognize the usb keyboard and if so it should install software and drivers
Posted on Nov 19, 2013
Testimonial: "Thank you for the reply. I have tried this and it sadly does not work.."
Acer aspire keyboard won't work
Click on the start button.
Right-click on Computer and select Manage
Click on Device Manager in the left pane.
Expand "Keyboards" in right pane.
Right click on any items and click on "uninstall"
Right click on the very top item, which should be your computer name, and click on "scan for hardware changes".
This will let Windows locate your keyboard and reinstall drivers again.
After this, make sure you're connected to the internet, and click on Windows update and install all available updates to ensure you have all of the latest drivers installed.
Oct 02, 2017 | Acer Computers & Internet
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
I used a PS/2 Keyboard and one day it stopped working. And I found out that when it's installed even the mouse doesn't work, so I bought a new USB keyboard though I can't enter the BIOS with it...
Hi, you maybe just need a driver for the mainboard.
You can download here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
Try the chipset driver first.
Please unzip the file before installation.
You maybe also need the driver for the usb controller.
Try to use a PS/2 mouse until the driver is installed.
Aug 28, 2011 | Biostar G31-M7 TE Motherboard
Usb keyboard no longer recognised during boot process
Restore your PC before the BIOS update. BIOS updates are not required until & unless you face problems while running a software and it will prompt you for BIOS update. Do this update if its vital othewise do not intergere in the BIOS. I faced the same problem and after unistalling all drivers and again reload the original driver from MB VD slved it. Another thing in BIOS is USB setting at high-spped & full-speed. Try changing those settings and retry. Mine worked!...sodeep
Mar 22, 2009 | ASUS Computers & Internet
Trying to install windows and at the boot screen have my keyboard and mouse plugged in windows doesnt see it.. I tried the USB keyboard and nothing I just recently replaced the MOBO using anti-static wrist...
I have seen this before, and the best answer I can offer you is some Motherboards are better than others when working with usb devices while no OS is in place. I actually tried using usb / to / ps/2 adapters and it still would not recognize the usb keyboard in a couple of instances. I had to get a ps2 keyboard for the installation of windows. After windows was installed I hooked up the usb keyboard and it worked fine. (just speaking from my own personal experience here)
Sorry I do not have a more technical answer for you but I'm almost 99.9 % sure this should work, providing there is no problem with the ps2 keyboard port on the Motherboard. I have never failed to install windows unless there was another hardware based issue of some kind, but never a problem with a known good ps2 keyboard.
Just double check everything is seated properly and try to get into the bios setup, if you cannot use the usb keyboard for this, you can try the usb / ps2 adapter, but if that doesn't work either then use a regular ps2 keyboard. That should work fine, then after setup is complete, windows is installed, then your usb keyboard should work fine.
Mar 03, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Just installed a microsoftwireless keyboard 4000 and installed software and it worked fine. When I rebooted my computer would not start untill I unpluged the new keyboard. Tried several times to the same...
Hello There,
This problem is not common,
Try these:
1) Re-install the software - see what happens.
2) Un-install the software if 1) doesn't work and try using keyboard.
3) Read about common problems in the software and keyboard:
http://support.microsoft.com/kb/258826
4) If all these fail then call Microsoft about this problem and let them diagnose it. They are the makers so they should know what to do.
Dec 27, 2008 | Microsoft Wireless Laser Desktop 4000...
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
USB HUB, Receiver & Keyboard
dude
Try to update windows xp service pack, i guess usb root hub drivers is missing, when you updated windows xp they will get fixed by itself
Dec 18, 2008 | Microsoft Windows XP Professional
USB Devices not recognized
Go into bios by pressing F2 on boot and make sure that usb support is enabled. If it is then boot and go to device manager and uninstall the usb devices, then try to reinstall. Instead of just updating the drivers.
Nov 29, 2008 | Foxconn 6150BK8MC-KRSH Motherboard
Open Questions:
Computers & Internet Logo
83 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
