Question about Nordic Track NordicTrack T 8.0 Treadmill
Jumps to highest speed then stops when started
There was an electrical surg in the home
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
RUN the software calibration for easy diagnostic and fix it. Follow the steps in your instr. manual. or download from www.fitness.manualsonline.com
God bless you
Posted on Nov 19, 2013
What would cause it to just click and the alarm to go off
Loose battery terminals. You should remove them, take some sand paper and sand the terminals a bit, removing any corrosion or "dark gray metal", and then using a WRENCH, tighten them back very securely.
The "click" sound is the sudden jolt of electricity (the amps are highest when the battery first tries to turn the massive engine over, then the battery output lowers to maintain the running engine)
We don't see this big jump in electricity at each start, but the surge of electricity is likely "pushing" loose terminals off the battery a bit, enough to prevent starting the engine, but not enough to disable the alarm.
Jun 06, 2016 | 2013 Toyota Corolla
Jumps to the highest speed setting when started
Run please the software calibration, ready your instru manual and follow the steps for diagnostic and fix it.
God bless you
Nov 19, 2013 | Nordic Track NordicTrack T 8.0 Treadmill
Car Surging
Possible wheel alignment or balance. Have front end checked
Jun 24, 2017 | 1996 Toyota Camry
My 1998 jeep grand cherokee surges at cruising speeds. also jumps in secound gear.
It sounds like you either have an Electrical Issue with the PCM or your Band is slipping and you are looking at a rebuild sometime soon.
Apr 09, 2013 | 1998 Jeep Grand Cherokee
After jump starting trunk latch,sunroof,door locks and map lights won't work
when jump starting volvos turn the lights on this will stop the power surge from blowing fuses or relays that have stopped all your bits from working
Jul 31, 2012 | 2001 Volvo S60
I have a renault megan 97 1.6 coupe got home from work the other day to find battery dead,jumped it got it going but had know indicaters, wipers,hazardslights,and the engine managagement light was...
It is fatal to jump start modern cars, The surge in voltage simply blows numerous computerised circuits. I feel that your only solution is to tow the vehicle to the agents for them to sort out
Feb 16, 2011 | Renault Sport Cars & Trucks
Hello; could you please help me to find the answer for this question; 1) what exactly is the surge, and what is the difference between surge and stall? please explain in a simple language because i have...
Stall is the state the armature is in just at startup. Your compressor will draw maximum power at stall. Some say there is a small surge some nano-seconds after the compressor gets rolling ... just as it begins to slow to operating speed.
A electric surge is a temporary increase in line voltage doe to any of a hundred reasons. There is a surge in your home everytime a motor starts. Lightening strike.
Have I properly addressed your question? or have I missed the boat.
Can I recommend Wikiedia for additional reading?
Thanks
Oct 19, 2009 | Air Tools & Compressors
Honda accord 1996 v6 2.7 liter,rpm gage jump up and down
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Nov 28, 2008 | 1996 Honda Accord
Oxygen sensor
no it wont cause it surg or jump
you might be able to fix it yourself but you need to get the codes
Nov 14, 2008 | 2003 Ford Windstar
Nordic Track NordicTrack T 8.0 Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
