Question about Canon Office Equipment & Supplies
Which paper type option on my canon ip1800 printer is best for card stock?
Gan !!! konvirmasikan riset print canon iX6500...lagi butuh nich gan...tolong yach gan...
Posted on Nov 19, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Posted on Feb 17, 2009
bob_computer
  • 3153 Answers
SOURCE: The printer will not pull card stock paper
Usually the stock is too thick to process properly.
Go to a lighter stock or buy a more robust printer if you are going to do a lot of that type of work
Posted on Aug 08, 2009
  • 12 Answers
SOURCE: Canon iP1800-alternating flashing lights. 1 long
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Posted on Apr 24, 2010
Printer only takes paper from one end resulting in a paper jam
I would not have believe this if I have not actually experienced it. Today, my Canon PIXMA MP470 started feeding my paper crooked, to the right where the feed roller is located. Did some research and found numerous people discovered foreign objects inside their printers. Since I had tried numerous other solutions, such as maintenance cleanings from the printer control area. I decided to unplug the printer, turn it upside down and shake it, hoping to dislodge a foreign object. It didn't work. I then took compressed air and sprayed vigorously inside the printer, and tried it again. It didn't work. I then took some card stock (the type used for making greeting cards), put it into the printer and began printing a word processed document - just something to get the card stock to enter the printer. I manually forced it into the printer as it started to print, then after the card stock was about two inches into the printer I manually pulled the card stock back, and THERE IT WAS! My memory card insertion slot protector from my netbook! Thank you Jesus! It is a small piece of black plastic that had fallen from the top of my printer, where I had foolishly placed it while I was using the memory slot in my netbook. Printer works great again! I hope this helps someone!
Jun 15, 2012 | Canon PIXMA MP470 All-in-One Printer
Dont know where to put paper in
The input paper tray for the iP1800 is accessed by opening the door / tray in the top of the printer. The door serves as the back support for taller paper. The paper thickness lever below the output roller needs to be adjusted depending on paper thickness. Most papers require that it be kept in the left position.
You can view the entire details of the printer by checking the details at:
http://www.printerinfo.com/content/Canon-Pixma-iP1800-Photo-Printer-Review-676/TourComponents.htm
Sep 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The same problem with my ip1800
Hi There, if you go onto the top of the page on this website and type in manula for canon ip1800 it will bring up the manual and it will show you how to fix it.
Jun 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
Paper in printer is jammed up
What specific model of printer do you have?
If it's jamming, make sure paper type is identical. Make sure the quantity is enough for the printer tol hold. Try to reduce the amount and clean the rollers of the paper tray/feeder using alcohol.
Jul 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printing business cards on Canon PIXMA iP1880
go into your printers folder from the start menu on your computer. right click on your printer folder and select printer preferences. Under the page setup tab you can select the paper size and type of printing you want. if you select the card type you should be able to print business cards
Mar 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
50 people viewed this question
old marine
old marine
