Question about Jet 3 Ultra Power Chair
Jet 3 ultra wheelchair with a new joystick controller it is still showing a controller error
My jet 3 ultra is showing a code for a bad controller. I put a new controller on the chair it also shows error for bad controller. what could the problem be?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Please contact a dealer tech,u may have a bad controller it happens
Posted on Jan 19, 2014
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Posted on May 06, 2009
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Posted on Sep 07, 2009
  • 103 Answers
SOURCE: we have a problem with the joystick controller on
The joystick is a sealed unit. If there is a problem with the joystick then you have to replace the whole unit.
Posted on Dec 15, 2009
Hi, well as long as it's operating Ok, then we are all good,and perhaps it is something simple, such as there is NO profile, or a Profile hasn't been set, or chosen?
www.pridemobility.com/pdf/...Manuals/US.../US_Jet_3_ultra_om.pdf
above & below, are your manual so you can check settings etc.
www.pridemobility.com/...Manuals/product_owners_manuals.asp
Below is your troubleshooting website How To.
www.pridemobility.com/.../basic_troubleshooting_guides.asp
Posted on Mar 29, 2011
  • 99 Answers
SOURCE: how do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Posted on Sep 05, 2012
Why controller light flashes but wont work
Flashing lights on a controller are showing you a trouble code. To find out what the code means, count the blinking LEDs.
Here's a link to Pride's troubleshooting guide for the Jet 3:
http://www.pridemobility.com/includes/download.php?f=troubleshooting/INFINFB2045_Jet_3_Ultra_Troubleshooting.pdf
Feb 05, 2015 | Jet 3 Ultra Power Chair
Have a jazzy chair purshased from scotter store. error code flashes 8 times. cant get anyone to come look at it what do i do?
If you have a GC Controller 8 flashes indicate a control system fault. Check all connections - especially connections to power module and joystick.
Apr 19, 2013 | Jet 3 Ultra Power Chair
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
My jet 3 has been sitting for 6 months, will the joystick light up when the onboard charger is in use. When I plug the onboard charger in the altameter raised to 3.5 and after charging for 12 hours drop to...
Hixx the batteries are too low to light up the joystick and no amount of charging will bring them back. Sorry you will have to get new batteries. You will need 2 U1 batteries. Hope this helps
Dec 03, 2010 | Jet 3 Ultra Power Chair
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
On my Ultra Jet 3 th power lights keep flashing?
Count the number of flashes IE 3 flashes a pause then 3 flashes this is a error code and tells the tech what the problem is. Without knowing the number of flashes I cannot help. If you have your owners manual there should be a page for error codes somewhere near the joystick page
Aug 16, 2010 | Jet 3 Ultra Power Chair
We have a problem with the joystick controller on my Mom's Jet 3 Ultra Pride. Is it possible to fix that?
Dec 14, 2009 | Jet 3 Ultra Power Chair
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
Sep 06, 2009 | Jet 3 Ultra Power Chair
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
175 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
