Question about Canon PIXMA iP1800 InkJet Photo Printer
Manually print cardstock - Canon PIXMA iP1800 InkJet Photo Printer
  • Matt Johnson
    Matt Johnson Nov 20, 2013
    I would like to know which "quality" and "paper type" options on my canon ip1800 printer would be best for printing onto card stock paper.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Buy a larger printer
Posted on Nov 22, 2013
When trying to print business cards they get stuck in the printer and wont move
Just a quick thought here. Check the paper thickness settings to see if you have a cardstock setting. Some printers need the paper thickness to be set to properly work. Also, when the sheet is printing, place you hand on the cardstock and see if you can help it along by pushing slightly. You may feel and see the obstruction. You can find additional information in the user manual under "Print on special and custom-sized media".
May 14, 2015 | HP OfficeJet Office Equipment & Supplies
Why is my hp 5610v not printing on cardstock?
Are you print through manual bypass? If not try doing it that way. Card stock is very thick and by using manual bypass it doesn't require as many turns for the card stock.
Apr 26, 2014 | HP Office Equipment & Supplies
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
Will not print evenly on cardstock business cards
This can be caused by the cardstock slipping to one side as it prints. Make sure when you print you are using the card stock settings found under your printer setup - paper type. Check to make sure that the paper you are usng is meant for your printer, most printers are meant for up to a certain pound of paper eg 120lbs. and going over this could mean that the paper is too heavy for your printer which causes the rollers to slip as it pulls the paper through your printer.
May 30, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My piece of cardstock paper keeps jamming barely out of the tray. is there something i can do to have it go all the way through. I have a samsung clp-315 laser printer.
Yes, you have to change the print properties on the computer to let the printer know it is using cardstock. Please refer to the owners manual to get the information. The manual can be found at www.samsung.com under the support section.
Nov 26, 2009 | Samsung CLP 315 Laser Printer
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Cardstock printing with OKI C7400
That machine is rated at 80lb cover I think. You have to use the bypass and select ultra heavy setting in the driver for cardstock.
Jun 10, 2009 | OKI C7400 Led Printer
Paper too thick?
You will need to use the manual feed and insert the cardstock one page at a time. First look at the rear of the printer for a purple dial. Roll the dial downward. This will allow the printer to exit straight out the back of the machine. Allow enough room at the rear of the printer so the cardstock doesn't hit anything on the way out. Next look at the front of the machine at the **** just above the paper tray. You'll see an envelope icon. Align the cardstock when manual feeding one sheet at a time to the left side of the **** next to the envelope icon. When you hit "file, print" select MANUAL FEED in the print window.
The 4L will only do cardstock by one at a time in the way noted above as the feed system isn't strong enough to make the sharp bend coming out of the tray or in the back to bend it around and into the top tray.
Sep 22, 2008 | HP LaserJet 4L Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
35 people viewed this question
old marine
old marine
