Question about Garden
John deere sabre 17 hs
Engine will not stop running when turning the ignition off and getting off the seat.
    Sergeant:
  • 416 Answers
Sounds like the safety switches have been by-passed
not shutting off at switch may be the switch
Posted on Nov 20, 2013
  • 133 Answers
SOURCE: John Deere Sabre 14.5/38 HYDR lawn tractorWont't
See if there is a plastic connector on the wires leading to the seat switch. If there is try disconnecting it and use a piece of wire (with insulation on it) to use a jumper. There is probably two wires coming from the tractor to the seat. After disconnecting Place one end of wire into the wire connector coming tractor and the other end of wire in the same connector on the other side. That will act like the seat switch is closed like you are setting on it. Try and start. Had the same problem on an electric hyster at work and that was the fix we used because the switch is pretty expensive and a hassle to change.
Hope this helps
roundo4
Posted on Aug 04, 2009
mickey813
  • 472 Answers
SOURCE: John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Posted on Oct 15, 2009
mowerman1857
  • 389 Answers
SOURCE: drive belt on a sabre by john deere 42 inch,
Since you didn't ask any question or say what you wanted to know about the belt, you can go to johndeereparts.com , click on parts catalog, enter your model number, click on sectional index and the click on Belt drive and Idlers for which ever transaxle you have. It will show you a very clear picture of the belt and its routing, also gives you the part numbers for each
Posted on Oct 31, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
John Deere sabre runs for a while then sputters to a halt. Won't restart until it cools down
check coil , ignition control module
This is an indication of component over heating and breaking down.
splutters as the circuit becomes unstable and eventual failure and refusal to start until cool
Jul 07, 2016 | John Deere Garden
I HAVE A JOHN DEERE SST18 AND WHEN I RELEASE THE BRAKE THE ENGINE STOPS
Hi Ray:
One of the "double" safety devices is that there has to be an operator sitting in the seat for the engine to run when the brake is off.
Review what happened between when the machine would run, and when the problem started.
Chances are you'll find a problem with the seat safety switch.
Cheers
Jun 26, 2016 | John Deere Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
John deere gx255 shuts down when brake released.
For sure the seat switch is the likely problem. The logic is if the brake is set the engine will start and run. If the brake is released and no driver in seat a saftey situation is possible and the engine turns off. Check seat switch, Bi pass to troubleshoot.
Hope this helps?
Jun 28, 2017 | Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Our john deere sabre 17.542 hs ride on mower will not go forwards or backwards.We're looking for a diagram of the hydraulic gearbox/diff
Nov 15, 2009 | John Deere Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
