Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How to make the phone ring continuously until someone asnwers it.
The answering system is off, phone will only ring 6 times, how do I get it to ring continuously without going to the automated message?
    New Friend:
Change the way you set it up.
Posted on Nov 19, 2013
  • 65 Answers
SOURCE: rings only 3 times then message
I did not see what model uniden phone you have. check here for a manual http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Feb 17, 2008
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Posted on Dec 17, 2008
  • 206 Answers
SOURCE: The phone only rings twice and then the automated
Click here to view some uniden cordless phone manuals and maybe you can find what you are looking for
Posted on Nov 18, 2009
  • 176 Answers
SOURCE: Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Posted on Jan 07, 2010
BillB-SA
  • 2761 Answers
SOURCE: How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Posted on Mar 04, 2010
Change number of rings on uniden phone model exi 8560
The EXI8560 isn't an answering machine. It will continue to ring until someone or some answering machine picks up or the caller hangs up.
To change the ring count on your answering machine, consult the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Jan 14, 2014 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
How to set ringer from 2 rings to 4 or more on v-tech vtcs6114
The CS6114 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected to your phone, consult its documentation. If you need further assistance, please repost your question and identify the answering machine.
Feb 26, 2013 | New Vtech Vtcs6114 Dect 6.0 Single Handset...
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
Dec 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
How do you change the amount of rings on the uniden dect1363 6.0 GHz
The Uniden DECT 1363 isn't an answering machine. It will continue to ring until someone picks up, a separate answering machine or voicemail system picks up, or the caller hangs up. You need to refer to the documentation for your answering machine or voicemail system.
If you require further assistance, please repost your question specifying the make and model of your answering machine or voicemail system.
Sep 18, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
Want to change from a 3 ring answer to a 5 ring answer
The CS6119 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected, please refer to its documentation or else repost your question and specify the make and model of the answering machine.
Sep 03, 2012 | Lands Phones
Change from 3 ring answer to a 5 ring answer
Need more rings before going to voicemail
The D1660 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up. Please refer to the documentation for whatever answering machine or voicemail system you have connected to your phone line.
If you need further assistance, please repost your question but be sure to specify the make and model of your answering machine.
Sep 02, 2012 | Uniden D1660 Cordless Phone
Number of rings uniden 6465
The DCT6465 isn't an answering machine. It will continue to ring until someone picks up or the caller hangs up.
If something else (fax, answering machine, computer, etc) is picking up the call after three rings, a good first step would be to determine the make and model of that device. A good second step would then be to repost your question giving the information from the first step.
Jul 10, 2012 | Uniden Telephones 6465-2
the ring time.
Bill B
Mar 04, 2010 | Uniden DXA15588-2 Twin Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
139 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
