Question about Le Creuset Winged Corkscrew Wine Opener, Antique Chrome | Williams-
Le creuset wine operner repair
How do I repair
Le creuset enamel repair
If the chip is on the outside of the pot, it should still be okay to use. If its inside the pot-this is a useful posting
http://www.thekitchn.com/chipped-enamel-need-to-replace-86730
May 15, 2013 | Mario Batali 7-inch Chianti Enameled Cast...
What is a great casserole dish to invest in?
Well it all depends on how much you can spend and if you want to be able to use it on top of a stove burner as well as in an oven. If you don't have a lot to spend, then buy caserole dishes which don't have to work on a stove burner as well. You can always use pots instead. You want something that heats evenly with out burning. I like Corell ware as it is not too expensive. Get a set with at least a lasagna pan, a two quart and a three quart casserole. I would not get the clear glass dishes any more as I just had one break into three pieces on me as it was taken out of the fridge after defrosting. Dinner went on the floor along with the broken glass.
OR if you really want an investment peice, go to Homegoods and buy an imitation of the French dishes Le Creuset Le Creuset Stoneware Deep Covered Bake or buy a real Le Creuset at Williams Sonoma.
http://www.williams-sonoma.com/products
May 01, 2013 | Home
Le creuset classic kettle replacement whistle
The replacement whistle for Alessi 9033 kettle allegedly fits Le Creuset classic kettles. See the customer comments on amazon. The only other replacement I've found is a genuine one on UK ebay.
Jan 29, 2013 | Kitchen Appliances - Others
I have an old Le Creuset 16cm frypan an food especially eggs stick to the bottom .Is there any thing I can do to fix this?
It probably needs re enameling but the good news is that Le crueset guarantee for life. I can't point you at a link as i dont know where in the world you are but if in the UK see here
http://www.lecreuset.co.uk/Care--Use/Cast-Iron/
hope that helps
Jan 25, 2011 | Microwave Ovens
I burned potato soup in my Le Creuset dutch oven.
Go buy a scraper for a ceramic hob and a can of barbeque or oven cleaner.
Spray the cleaner on and leave it for 15 minutes put on a pair of rubber gloves and use the scraper to break the surface of the burnt on stuff.
Make sure you keep the blade of the scraper as flat as possible to the surface of the pot.
Once you have scored some of the surface spry on some more cleaner and repeat the process
I clean off burnt casserole dishes using that method
Jun 20, 2009 | Le Creuset Q9500.67 Electric Kettle
My oval Le Creuset dutch oven is cracked on the side. Any way to fix it?
Yes there a foundation repair solution that should repair it sufficiently. Check at Home Depot or Lowes. Any hardware store should be able to help you out.
Sep 03, 2008 | Le Creuset Kone Electric Kettle
Le Creuset Kone Electric Kettle (apparently)
no because it isnt realy safe to do that because the tape can melt
Nov 27, 2007 | Le Creuset Kone Electric Kettle
Le Creuset Winged Corkscrew Wine Opener, Antique Chrome | Williams- Logo
Top Le Creuset Home Experts
Donni Steen
Tom Chichester
Are you a Le Creuset Home Expert? Answer questions, earn points and help others
