Question about Facebook Social Network
What is wrong with charlie morris of charlie bears
Is charlie morris of charlie bears anorhexic
  • 2,113 Answers
I've never heard of either of them. Perhaps because i am Canadian
Posted on Nov 19, 2013
How to replace clutch
disconnect battery, remove screws holding floor down, the part covering the gearbox, remove starter motor, unbolt driveshaft at gearbox end, remove tin cover bottom of bellhousing, undo rear mount bolts, remove all bell housing bolts, with front seats removed you can lift the gearbox out of the car, ensure anexact alignment of the clutch plate and pilot bearing in the flywheel when fitting new parts, you can use a small socket and extension bar to align them. reverse procedure to refit components. good luck.
Jun 20, 2014 | 1969 Morris Minor
Morris Minor
contact a morris club for a good idea as to the value. Remember the car will only have value if restored to as new condition using genuine parts. I would start at around $30.000.00 aud
Jun 03, 2013 | Cars & Trucks
Insulator on coil lead melted on morris oxford 1969
Hi sounds like you have a bad earth issue or faulty or wrong coil Morris usually run a Ballast resistor in the ignition to coil as the standard coil is about 9 volts, if you have rewired with normal wire you will have 12 volts at the coil overheating it
Must have good clean earthing between :
Body, Engine and chassis
Also check terminals under the fuse box for corrosion
Feb 22, 2013 | Morris Oxford Cars & Trucks
My 10 inch miter saw makes a grinding noise when it slows down or when i make angled cuts
The motor needs new bearings. These are standard bearings which can be obtained from a motor repair shop via the number on the bearing. There are two of them. This is not a terribly difficult job for someone with experience, but neither is it simple. More info, let me know.
Charlie
Feb 19, 2011 | Craftsman Garden
I have a 1999 legacey 2.5 GX. There is now a loud metallic sound when driving. the sound stops if you depress the clutch but returns after. Any ideas.
This sounds like a throwout bearing failure. Transmission will have to be pulled -- might as well replace clutch, disc, and throwout bearing -- how many miles on the vehicle?
Charlie
Aug 19, 2009 | 1999 Subaru Legacy
Facebook Social Network Logo
669 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
