Samsung hlp-5063w no picture when its on
Samsung hlp5063 makes a buzzing sound but produces no picture: keeps cutting on & off
    Problem Solver:
  • 15 Answers
Do you have three flashing lights on the front? You most likely have a problem with your lamp or color wheel. Those two component combined are pretty much the guts of your TV. If you are handy, you can replace those parts yourself. I have a 50" Samsung DLP and I've already replaced those to items myself. Otherwise, you can contact Samsung at 1-800-SAMSUNG and they can assist.
I bought my parts using Amazon, had them shipped to me, and took an afternoon to take about the back of the TV; documenting everything and taking photos of the progress, until it was done. There may be video tutorials on Youtube. There was for my model (HLS5086). Here is a great link to help you along. Good luck.
http://blog.trebacz.com/2011/01/50-samsung-dlp-hl-p5063w-with-3.html
Posted on Nov 19, 2013
4 Suggested Answers
  • 5479 Answers
SOURCE: hlp 5063w on off front
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Posted on Sep 30, 2010
  • 4102 Answers
SOURCE: Samsung HLP 5063W
Hi it sounds like the problem is with the convergenge ics these can be replaced but the problem usually comes from a bad resistor this causing the ic to go.
The only problem is without having the proper testing equipment in front of you you could keep guessing and never find the problem the best thing to do is if you dont have the equipment nor the knowledge of diagnosing the problem it is best left to somebody who know what they are looking for.
I see this problem often on these sites and it all comes down to the convergence ic failing they usuall fail to a resistor failing on the main board the board will need testing and tracing back from the ics to eliminate any resistors that could have failed.
I have seen alot of people that have replaced the ics without checking the resistors and then they have the same problem shortly after.
The resistors tend to start failing shortly after the warranty has run out.
The cheapest sollution would be for you to take the tell yourself to repair shop as calling somebody out might charge for the call out and for transporting the tell.
Their isnt much you can do yourself but if you need it i can get the spec sheet for you so you can follow circuit diagrammes let me know what you want to do
Posted on Dec 01, 2007
circuitworld
  • 335 Answers
SOURCE: samsung tv hlp 5663wx/xaa
You need to change the color wheel, if you want a temporary fix use WD-40 on the wheel bearings. This will stop the noise for a month or two....... but eventually you will need a new wheel then go to service mode and align the colors under 'index delay'..........
Posted on Nov 04, 2009
Samsung HLP 5063W
Dec 01, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Just replaced color wheel for samsung hlp 5063W and my on screen color is wrong. how do I reset on screen colors to original factory settings?
You may have to do a reset in service mode....sorry - don't have the guide but it should be in the usermanual for this model.
Aug 27, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hi, my problem with our Samsung HLP5063 WX / XAA is that ever so often it decides to buzz. The buzzing sound is coming from the back of the tv and happens at different times. Sometimes the buzzing starts...
Bryce.
My experiance with what you are talking about is sounding like the color wheel going bad. Same thing happened to mine and it was the color wheel. Right around 120.00 and is a easy do-it-yourself job.
Feb 06, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
MY SAMSUNG HLP5063 HAS SOUND BUT NO PICTURE ON ANY SOURCE OF MEDIA
have you replaced the bulb already this lamp are made to last 6000-8000 life hours and if you have not replaced the lamp yet that would be the first place to start,here is the lamp you need just in case
http://www.discount-merchant.com/Samsung-BP96-00608A-Lamp-Enclosure-p/samsung-bp96-00608-lamp-enc.htm?1=1&CartID=0
Oct 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Model 5063W - loud noise
The picture is pink, that would point more toward the color wheel, and you can see the fan through the vents in the back and you can go from there. It sounds more like the color wheel since you have a picture malfunction.
Jun 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hlp 5063w humming noise
Can you reseat the lamp?  Don't forget to unplug the TV of course, but sometimes the connection between the lamp and TV degrade due to heat contraction and cooling.  Some TV's provide an error code by having LED's flash a certain way, is this what you mean by lights flashing?
Mar 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Ps 3 no data
Try holding the power on button down until you hear a series of beeps, each one representing your ps3 switching video modes. try this until you get a picture on your screen, then you can use the options to set it to your tv's resolution. I've seen this same problem often from people holding the button when they turn it on :3.
Hope this helps.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
