Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Mu fridgiaire electrolux pro series model #PLEB3058ccc lower new element stopped working
What causes this problem
2 Suggested Answers
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
Electrolux microwave oven. model no. NF40065 browning element not working
The safest way to check it is to disconnect it from the mains. wait 15minutes in case the capacitor is still charged. Remove the cover and check for a low resistance across the element. It should read less that 180R.
It is a standard element so spares from a model number near to yours may fit.
Jan 03, 2018 | Electrolux Ovens
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 | Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Main oven will not heat up
Check the lower heating element, you should test the element for continuity, and inspect element wirings for a short.
If it is only the lower part that is not heating, and the circuit breaker tripped off, then it is usually a faulty element.
You can get parts from the following internetional part sellers:
Repairclinic
PArtselect.
Contact them if the part or the model is not in list.
Oct 26, 2008 | Ovens
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
Jun 30, 2008 | Frigidaire 30 in. Electric Gallery Series...
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
51 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
