Question about Chicago Pneumatic 1" Cp797 Air Impact Wrench Standard
On the CP-797, do you put oil in the hammer case?, there is a small plug up front.
    Habit-Forming:
    Scholar:
  • 102 Answers
Some of the early CP797 used grease, the current models use oil.
To identify your tool look at the front of the hammer case where the anvil is located and look for a seal (item# 115) if it is present then you tool uses oil, the manual states that the tool requires 6 ounces of SAE30 oil use non detergent type.
Follow this link for the owner's manual:
http://etools.cp.com/cpvscatalogue/files/CA155616.pdf
Posted on Aug 31, 2014
  • emilio cruz
    emilio cruz Aug 31, 2014
    http://etools.cp.com/cpvscatalogue/files...
Is the oil used for CP734 air wrench for air line use & air gun body oil one & the same product
C.P. recommends 3/4 oz. of SAE30 oil in the hammer (clutch) mechanism, and SAE10 for the air motor.
Feb 21, 2013 | Chicago Pneumatic 1/2" Air Impact Wrench
My cp797 impact wrench after oiling and checking psi 110 still just air shaft not turning
YOU WILL NEED TO DISASSEMBLE THE TOOL.
START BY REMOVING THE HAMMER CASE AND INSPECT THE ANVIL AND HAMMERS FOR DAMAGE, AFTER TRY AND TURN THE ROTOR SHAFT IF LOCKED YOU WILL NEED TO DISASSEMBLE THE AIR MOTOR AND INSPECT THE PARTS FOR WEAR OR DAMAGE.
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC.
May 14, 2012 | Chicago Pneumatic Air Tools & Compressors
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
What type and weight of oil should be put in thru the allen screw hole in the gear case of this impact? CP 7750 turbo Thanks,
air tool oil, its a special oil, you can use marvel mystery oil also, but would go to auto parts store and get air tool oil
Sep 15, 2011 | Garden
I just fixed my cp 734 i cant find how much oil should be in hammer unit please help thank you
This is from the CP734H manual.
Check clutch oil once each month. Use 3/4 oz.
(22ml) of SAE#30 oil or equivalent.
Make sure the oil is non-detergent.
Mar 25, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
How to change oil 1978 goldwing gl1000
Get 4 quarts of JASO MA certified motor oil. I recommend synthetic , it will shift better when hot. Amsoil is a good choice. Place an oil pan under the front of the motor. Use a 6 point socket to loosen the bolt on the round finned oil filter cover on the front right corner of the motor and spin it off.Take the oil filter out of the cover and make sure you save the washer that will stick to the rubber seal. Pull bolt out of cover and replace o-ring. put bolt back thru cover, first slide on spring,then washer,and then filter and spin back onto motor pressing filter against engine case. Snug bolt but do not over tighten. Now remove bolt in the middle of the front/bottom of motor(large one in middle , NOT small one under water pump). Check aluminum washer,if bad replace.After oil has drained put bolt back in , do not over tighten.Take off fill plug on right rear corner of motor(by final drive shaft) Using a funnel pour in 4 quarts oil (3.9 is correct amount, 1/10th quart does not seem to bother anything). Put plug back in , start up, and check for leaks.
Jun 02, 2010 | 1978 Honda GL 1000 (K3)
Oil leak under front sproket
The oil seal on the sprocket shaft has probably gone bad. Remove the sprocket then clean the shaft to aid in removing the old seal. A screw driver and small hammer is used to pry the outer edge of the seal inward. Realize that you will butcher the old seal in the process of removal. The only other way to remove the old seal is to pull the engine and split the center case.
Jan 18, 2010 | 2001 Yamaha YZ 426 F
The drain plug on chevy van will not come off so we can change the oil. We are stiping it and it isn't any looser. What should we do?
Stripping it? Do you mean your rounding the head of the plug? If that is the case, you'll need to use vise-grips or channel loc pliers to remove it.
Take a hammer and pound the plug as if you were pounding it into the drain hole, that will help to loosen the crud that is prevent its removal. Use good judgment when hammering the plug, don't cave in the oil pan.
Once you get it out, buy a new plug to put back in
Oct 02, 2009 | 1999 Chevrolet Venture
Front sprocket oil leak
Get a new seal before taking the sprocket off. Remove the sprocket cover plate. You will see two small bolts holding a lock plate on the sprocket. Remove the bolts, lock plate and sprocket. Clean the sprocket shaft so the new seal is not damaged when installing. Now just pry out the old seal any way you can with a screwdriver and small hammer. Install the new seal flush with the casing.
May 20, 2009 | 2005 Suzuki RM-Z 450
I have a 92 model nissan largo ld 20 diesel engine 4 cyl i have replaced glow plugs but when i put battery on it blew my relay wire near the battery and the plugs are 2xcp70 and 2x cp 71 is there a...
in a 4 cylinder diesel 2x cp 70 in front cp71 in the rear the reason why inline fuse blew cause by an electrical fault in the alternator thanks heaps after the alternator was replaced it work
Jul 17, 2008 | Nissan Minivan Cars & Trucks
Chicago Pneumatic 1"  Cp797 Air Impact Wrench Standard Logo
258 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
