Serial no:A78 2 slice sandwich toaster by Dualit. Toaster is missing element retaining plate, according to Dualit this means it cannot be fixed...and can they have it for their showroom?! It worked fine for the last 10 years, apart from toasting very slowly and then recently tripping my electric, so I thought some new elements would do the trick. is it fixable? Please is it? I'm ridiculously attached to the old thing! Thanks for any advice...Harriett.
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time. You can follow the instruction in the link what to order and how to replace. We have the procedure here in this link http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements Good luck
You can get any part you need at the Dualit Repair Center: Electra-Craft 41 Woodbine St Bergenfield NJ 07621 phone 201-439-1700 fax 201-439-1701 [email protected] www.electra-craft.com
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the six in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
The Dualit Repair Center is: Electra-Craft 41 Woodbine St Bergenfield NJ 07621 phone 201-439-1700 fax 201-439-1701 [email protected] www.electra-craft.com
