Question about Microwave Ovens
Kambrook manuals for pb.3 power board - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Go to www. retrevo.com or www. manualslib.com however you can see the diagram attached.
God bless youkambrook manuals for pb.3 power board - 0ed1a3d1-3aa3-4ade-8d12-cf2019178104.jpg
Posted on Nov 19, 2013
My over the stove microwave starts continues for a few econds the f-7 appears and it stops
F7 means power to magnetron is interrupted.
I don't recommend that someone without experience and an understanding of the safety procedures undertake troubleshooting this.
You can find manuals and helpful exploded view diagrams for your model here and my favorite parts supplier is here. There is a technical sheet hidden behind the controls that has helpful technical and troubleshooting information. It will say something like this:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Oct 05, 2016 | Kenmore Microwave Ovens
Instruction Book for Kambrook Convection oven
try their website for a down load
Aug 18, 2014 | Microwave Ovens
White westinghouse range
A model number would help, but if it's really old, information may not be available.
If this is a simple mechanical lock which you're supposed to be able to lock and unlock by hand, maybe it's rusted. A penetrating oil like PB Blaster may help.
If it's a relay-drive lock that's controlled by the circuit board, then it may need board repair, etc.
Jun 08, 2013 | Microwave Ovens
After a recent power cut my Kambrook Microwave has stopped heating. All the other functions seem to work, just doesn't heat the food ?
check the thermal hv fuse located near the transformer or check its continuity from line source
Feb 24, 2011 | Microwave Ovens
My microwave shows an error that says c-5 what is it
That would be "CS", which means low current sense.
CS Current Sense
Current Sense - Indicates control is sensing low current
(Amp) draw. Check components which would allow unit
to run but produce no heat or low heat. Current sense
circuit is active only when using pre-programmed pads.
Time Entry feature will by-pass current sense circuit.
Red wire from cavity T.C.O. must be routed through
current sense loop on H.V. Board.
Possible Causes:
1. Interlock switch (contacts 2 & 3).
2. Open thermal cut-out (magnetron).
3. Open/loose wire.
4. Power relay.
5. H.V. Board.
6. Magnetron.
7. Diode.
8. Capacitor.
9. Transformer.
10.Triac.
See the full service manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 01, 2010 | Amana RC17 Microwave Oven
Kambrook Bread maker kbm130 user manual
lve got a manual for a Kambrook KBM130 Home Bake Bread Machine..gpbrooks2@bigpond.com
Sep 20, 2010 | Microwave Ovens
Can i get a display screen for a sharp microwave model # R-530ES, and if you can provide this display, can it be shipped to miami?
The relevant service manuals are HTML clipboard here and here. hey contain detailed disassembly instructions.
There are three ways to get this fixed:
1. You could order a new power unit (lower board assembly) and a new upper display board assembly, solder them together, then replace your assembly with the newly assembled one.
You'd need the following parts:
DPWBFC167WRKZ CPU/LSI/display unit $107.07
DPWBFB094MRU0 power unit $53.09
Which can can be ordered from Encompass here.
2. This option is more difficult, but cheaper. You would order the upper circuit board assembly, desolder your old one from the lower power board, then solder the new upper board onto your power board.
You'd only need to order this part:
DPWBFC167WRKZ CPU / LSI / display unit $107.07
3. You could send your control panel assembly for repair for $39.95 with a one-year guarantee. Details are HTML clipboardhere.
Aug 31, 2010 | Sharp R-530ES Microwave Oven
Whirlpool microwave oven
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It says:
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
If for some reason your tech sheet is not there, you can download it here.
We regularly repair control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 30, 2008 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
