I have a 1995 ford taurus which i bought used. I've been having issues since people know the code and my key won't work. I was wondering if there is a way to disable the keyless pad and would my key work then?
SOURCE: keyless key pad entry code
Ford cars and such will put a sticker on the hinge or back gate with the numbers on it.
It will just be a white sticker with black numbers. A five digit code.
God Bless Greg
SOURCE: 1999 ford taurus,come with keyless entry or not ???
The code is printed on the right-hand side of the plastic housing for the keyless computer, just to the left of the steering column under the dash. Helpful pictures were posted on www.taurusclub.com:
SOURCE: Help with finding keyless door pad codes and resetting
Open the trunk and up under the package tray where rear speakers mount,on the passenger side you will see the module.It will be black and have 3 connectors to it.It will have a sticker on it with a 5 digit code.It will also have a sticker on one of the trunk hindges with this code if someone has not removed it.Here is how the system works:
Keyless Entry Keypad
To unlock the driver front door (20124), and disarm the anti-theft alarm control (19A366) (if equipped):
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver front door or luggage compartment door (40110) .
To unlock the luggage compartment door, press the 5/6 button within five seconds of unlocking the driver or passenger door(s).
To turn on the interior lamps (13776) and light all illuminated components, lift either front door handle (22404) and press any button on the keyless entry keypad (14A626) .
To lock all doors, press the 7/8 and 9/0 buttons at the same time. (It is not necessary to enter the key code first.)
This will turn off courtesy lamps.
To program a temporary code:
SOURCE: factory keyless entry pad code where is it please.
You can take your registration and driver license to a dealer and they can use their diagnostic tool to retrieve it from the computer. It should cost 1/2 hour of labor. Call first & ask.
Also, look in glove box for a plastic "credit card" with the code on it.
SOURCE: Remove or disable keyless entry code.
this code is located on a module on inside left rear panel where your car jack is located you will need a flashlight to look up on the module there will be a sticker on this module with 5 digits this will be the original factory code to lock or unlock your car . inside your owners manual there is a procedure to change the code .
