Question about HP Pavilion dv7-1260us Notebook PC
All three Led (power ac, disk drive) flash when I try to power on
The Leds flash together at about one per second
    Top Expert:
  • HP Master
  • 25,752 Answers
Try this.
Remove the battery and power supply. Press the power button and hold for 30seconds to discharge all reset ports. Connect the power unit and press power.
Posted on Nov 19, 2013
  • 324 Answers
SOURCE: Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Posted on Nov 05, 2007
  • 239 Answers
SOURCE: HP Pavilion DV9009us does not boot
I not sure what your saying, Is it the laptop thats not working ? Or DVD drive ? If Its the Pc Try and get into you Bios, Are you able to see the Hp Logo when you first turn power on, Or is Absolutely nothing Happening, No screen at all. Try and make sure, may be someone set it down a little harder than normal and may have jarred the Memory Module loose, Or even the Hard Drive it self may have become loose try to remove the Hd screw and remove and reset firmly back into place, If not, Just a little more Information may help us out, Thanks and I hope this works for you. bear001 Oh yeah If you can see the Hp logo, when you see that repeatedly push the F2 key or the Delete Key until your bios opens and try and reset back to Default Settings,
Posted on Dec 25, 2007
tat4u
  • 520 Answers
SOURCE: HP Pavilion zd8000 don't startup
remove battery plug in power cable boot up.. nothing may seem to happen but wait a minute or so then press and hold power button down until power light goes out then release button .
try to reboot now.
Posted on Jan 28, 2009
  • 148 Answers
SOURCE: omnibook 6000 will not run POST. Has LEDs permanently on
When was the last time a BIOS update was done? See if one is available for this laptop and give it a try. FOLLOW THE INSTRUCTIONS TO THE LETTER WHEN DOING THIS OR YOU CAN RENDER THE LAPTOP INOPERABLE!! If youre not comfortable doing this, have a service technician do it for you. Sounds like the problems really went into overdrive when the new drive was installed.
Posted on Mar 02, 2009
kbdesign
  • 370 Answers
SOURCE: My HP laptop is not booting
Try tapping on F11 after you turn the laptop on, and see if it will go into the recovery mode. If it does, you are in luck, and can choose how you want to do the recovery.
If it does not, you can order a set of recovery disks from HP for about $15us which includes shipping costs. Or, you can load any retail version operating system, and download/install device drivers from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839164&taskId=135&prodTypeId=321957&prodSeriesId=1839143&lang=en&cc=us&submit=Go%20»
Good luck, and please rate my response.
Thank you
Posted on Mar 15, 2009
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Ge 15318 Timer LEDs
The LED flashing every 20 seconds appears to be a feature of the timer so that you know what the last setting that you used.
As per the user manual, I could not see a way to disable this feature.
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15318-Manual-English-Spanish.pdf
Oct 29, 2013 | Hardware & Accessories
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My Printer Brother Type HL-5250DN.. All 4 led is flashing.. allready take out and put in back toner.. still not working yet.. 4 light still flashing. Need help soon.. Thanks
If all the LEDs then try to turn off the power switch, wait a few seconds, and then turn it back on. If all the LEDs are still blinking, press Go and Job Cancel buttons together and let me know what LEDs stay on.
Nov 16, 2010 | Brother HL 5250DN Laser Printer
Not switching on
Hi, Disconnect your ac adaptor from the laptop and remove the battery for about 30mins. Then keep power button pressed for about 10 seconds. Now fit install the battery and the power lead, wait for the mains led to liight which should also show the battery led as being charged, after 20 seconds, power up the laptop.
It should now power up, if not check if any flashing leds are present and if the lcd screen tries to light up.
May 11, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Omnibook 6000 will not run POST. Has LEDs permanently on
Feb 28, 2009 | HP OmniBook 6000 Notebook
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
HP Pavilion dv7-1260us Notebook PC Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
