Question about GE 31GT740 31" TV
P[ease tell me how to remove the chassis from the tv ge mo.31gt740
  • 2 more comments
  • julian nombrano
    julian nombrano Nov 18, 2013
    i canot under stand where my answer is
  • julian nombrano
    i can not see my answer posted this my first time on this web
  • mikadot
    mikadot Nov 18, 2013
    I just undo the screws, remove any wire harnesses and try sliding out the board. Take photos and mark connectors in case there are two that are alike.
  • julian nombrano
    julian nombrano Nov 19, 2013
    thanks for the info. i will give it a try
  • 2,113 Answers
Because no-one knowledgeable about your problem was online yet to answer it. It could take 10 minutes to a day to get an answer.
Posted on Nov 18, 2013
2 Suggested Answers
  • 236 Answers
SOURCE: Vide problem
I think you have a problem in the vertical circuit in your tv. It sounds like you have a loose solder joint. The set would have to be taken apart and re-soldered. You really have an RCA chassis inside your tv. RCA's have a lot of bad solder connections. Stargazer
Posted on Mar 03, 2007
What is the fly back part number for ge 31gt740
There is three numbers are used with model to model. It will differ according to chassis fitted with it. All chassis number will be the same, but the layout will have some difference, and company does it meant for advanced performance. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Schematic diagrams to some GE sets are given, that I can't upload by this window. Refer it. You can make sure about this detail, by contacting the authorized service center for GE; providing the exact model and chassis number.
Jul 04, 2014 | GE 31GT740 31" TV
I have a GE guide+ gemstar model 31GT740 i cant get cable reception the cable is fine as i hooked them to another tv and it worked fine i did auto channel and it scanned all channels when it was done it...
your have problem with the system IC's which store the channel and all the control in the TV or it can be remedy by soldering the pin of the IC's if the problem persist well your have to replace that system.
Sep 07, 2011 | GE 31GT740 31" TV
I own a GE 31gt740 and I heard a squealing noise a few times, but TV still worked. Then, I turned it on one day, heard the squealing noise, then saw a little smoke, some crackling, and no sound or picture....
I think that the problem of your tv is the flyback transformer. The noise you are hearing is the high voltage, it is leaking from the flyback transformer. The smoke you see may came from the flyback or the capacitor. To be sure to the problem, try to remove the back cover of your tv but be sure to unplug it. Try to plug it, then turn on your tv but you should turn of the light so you could see the high voltage that is leaking but be very careful when doing it.
Jun 21, 2011 | GE 31GT740 31" TV
My tv turns itself on and then starts going thru the channel and when it is on will start changing channels?
Assuming your TV continuously changes channels on its own in the upward direction, I had the same problem with my GE 31GT740 TV and fixed myself. GE will give you the runaround and have you calling RCA who has no clue. The cure is simple but, you need someone to help you move the set around. Remove the rear cover by taking out all of the screws – obviously unplug the set first. Then remove the large circuit board by taking the two screws out from the underside. The TV will need to be laid down on the screen side so have a large pillow or blanket laid out. The main circuit board has two side stops that hold it in and then pry it a little. The entire board slides out and you can set it aside. Now, remove the front switch panel assy by depressing the two side stops. Then the circuit board behind the switches can now be removed from the assy. The third button in from the center is the ‘up channel button’. Pry off the small switch soldered to the board behind the ‘up channel button’. Reassemble and the problem will be fixed. In other words, the ‘up channel’ button on the TV set has gone bad.
Jul 28, 2009 | GE 31GT740 31" TV
GE 31GT740 TV problem
hit the clear button on the remote and it will clear the guide plus off the screen
Jul 09, 2008 | GE 31GT740 31" TV
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
31GT740
The GE (actually RCA) 31GT740 uses the CTC203 series chassis. The first thing I would do is resolder the coil on the base of the horizontal output transistor and the pins of the horizontal drive transformer, as well as any other solder joints on the main PC board that look weak or cracked. 9 times out of 10 that cures the symptoms you described. If you do not have experience soldering parts on PC boards then have a qualified tech handle it for you.
Jul 26, 2007 | GE 31GT740 31" TV
GE 31GT740 problem
Sounds like you could have a bad Picture tube, as the filaments may not be lighting, as they are open, or maybe a video problem, or perhaps a problem in the Sweep power supply. This is an inexpensive TV set and will most likely cost more to repair then you could purchase a new TV for. Good Luck
Jun 21, 2007 | GE 31GT740 31" TV
Vide problem
Mar 01, 2007 | GE 31GT740 31" TV
Squeals Like a Pig
REPLACE HORZ OUT TRANSFORMER
Nov 06, 2006 | GE 31GT740 31" TV
GE 31GT740 31" TV Logo
91 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
