Question about Exercise & Fitness
Console isn't working
The console on my proform elliptical 490 le recently stopped working without warning. It doesn't come on at all, how can I fix this?
    Top Expert:
  • 12,223 Answers
1) Adjust Reed Switch see the diagram, test it, clean it and tight the connector very well.
2) see if the fuse are o.k
3) tight the ribbon cable inside console board, and clean it.
4) see if the power goes on.
5) Replace batteries if your system ( have it) clean it the spring contacts battery for corrosion, oxide, etc.
God bless youConsole isn't working - 5d329d1b-2520-4925-8090-458da0659816.gif
Posted on Nov 19, 2013
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
ercupa190
  • 12223 Answers
SOURCE: proform 540 console doesn't work
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill andremove the motor hood cover. The reed switch is mounted on the frame next tothe front roller pulley. There is a magnet glued into the front roller pulley.When adjusting the reed switch, make sure it is pointing directly at themagnet. Move the tip of the reed switch within 1/8" of the magnet. Also,check to see that the wire is not damaged, and is connected to the console. clip_image002.jpgOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk.
After you did these adjustments: Please tight the keypanel flexible cable vs display board and then tight the connector from display board vs lower board.
Try to clean the keypanel with spray contact cleaner with carefully and patience.
See diagrams. Good luck, sincerely. G-d bless you.
12_6_2011_5_46_41_pm.gif12_6_2011_5_46_57_pm.gifWith the block diagram that I did you will have a strong resultant if the keypanel board is faulty or display board completely. See how the main motor control has 90% functions in any treadmills.
E.CUADRA
MANAGUA, NICARAGUA.
Posted on Dec 06, 2011
ercupa190
  • 12223 Answers
SOURCE: Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Posted on Aug 30, 2012
Proform 500 LE Elliptical. Suddenly, why won't it turn on at all?
Check for a loose connection when plugging it in, verify that the main cable is connected to the console and the console also runs on batteries. You can try replacing those and use it that way with no adapter. They recommend alkaline batteries and if that still does not work, opening up your machine and verifying no cables are unattached or crimped would be best.
If you have any further questions please do not hesitate to contact us, i will be attaching a link to your manual also
888-713-2880
http://www.sportsmith.net/productsearch.aspx?dsNav=Nrc:id-772794-dynrank-disabled%7cid-750447-dynrank-disabled,N:773361
May 26, 2015 | Proform Exercise & Fitness
Proform elliptical
the cord could be coming loose during use or is bad
Aug 20, 2014 | Exercise & Fitness
Proform 500 le elliptical
I would suggest that there is a wiring fault or dry joint. you need someone who is tech savvy to check inside the head.
Jan 28, 2014 | Exercise & Fitness
Proform 490 le elliptical console no longer works... how can I fix this?
clip_image002.gifadjust the REED switch, see the diagram attached.2) test the adapter and see if there voltage and compare with the label attached.3) replace the old battery by new ones, clean the spring contacts from dirty, oxide, corrosion.God bless you0ea86ba1-4fc4-4bc7-82a3-5182fd575aca.gif
Nov 18, 2013 | Exercise & Fitness
Display on Proform 490 LE elliptical shows FF -- How do I fix it?
1) PLEASE replace batteries by new ones.
2) clean the batteries contacts with special spray contacts cleaner
3) retight the spring contacts batteries with a pliers for better contacts very important!
4) adjust the reed switch see the diagram attached.
God bless yu
Jul 08, 2012 | Proform PFTL79807 - 850 W/ Gamefit...
After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Just bought my Proform 490 LE elliptical 1 day ago and it has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried...
Mar 13, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
140 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
