Question about Poulan Garden
P3816 choke won't stay out - Poulan Garden
    Sergeant:
  • 417 Answers
However it is mounted to the actual saw, that piece is loose. Try to determine if it's a screw you can toghten or not, but don't over tighten, just a slight drag when sliding it back and forth should prevent it from loosening from engine vibration.
Posted on Nov 23, 2013
When I pull my choke out to full,it won't stay out.And is the on,off switch supposed to click to turn on?
Mine did the same thing in addition the choke was very hard to pull out manually. My solution was to remove the cover and blast the linkage choke and switch linkage thoroughly with WD40. Then manually work the choke in and out and the switch up and down till it feels acceptable. You will not get it as easy as it should have been from the factory but it will be a lot better.
Jon
Jul 07, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Do you have owners manual
http://lawn-garden.needmanual.com/2010-poulan-p3816-chainsaw-owners-manual.html?d=df_m_en
May 01, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
2000 Honda VT 750 C2 Shadow choke won't stay out
Hi, Berniequzewi for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Choke won stay on 03 750 ACE
Choke won stay on
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Apr 08, 2012 | 2000 Honda VT 750 C2 Shadow
Won't stay on when choke is pushed all the way in
idle screw or tickover out of adjustment , Dirty carbs
Jan 27, 2012 | 2009 Yamaha V Star Classic
2004 Kawasaki KX 250 F choke lever will not stay up
Hi, Anonymous for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Choke won stay on
Choke wont stay up No problem watch this easy fix
http://www.mxguy.com/downloads/service_manuals/2004_KX250F_Service-Manual.pdf
OEM Parts for Kawasaki
2004 Kawasaki KX250F Owner Manual
Jan 01, 2012 | 2004 kawasaki KX 250 F
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Garden Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
