Question about Exercise & Fitness
Proform 490 le elliptical console no longer works... how can I fix this?
    Top Expert:
  • 12,223 Answers
proform 490 le - clip_image002.gifAdjust the REED switch, see the diagram attached.2) test the adapter and see if there voltage and compare with the label attached.3) replace the old battery by new ones, clean the spring contacts from dirty, oxide, corrosion.God bless you
Posted on Nov 19, 2013
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Posted on Apr 11, 2010
Testimonial: "Thank you very much for your advice! Very helpful!!"
ercupa190
  • 12223 Answers
SOURCE: Proform 480 LE Elliptical screen does not work, but everything else works properly
5_3_2012_7_37_07_am.gifclean the contacts batteries for OXIDE, very well, see if some wires is loose.
Try to RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: Display on Proform 490 LE elliptical shows FF -- How do I fix it?
1) PLEASE replace batteries by new ones.
2) clean the batteries contacts with special spray contacts cleaner
3) retight the spring contacts batteries with a pliers for better contacts very important!
4) adjust the reed switch see the diagram attached.
God bless yu
Posted on Jul 09, 2012
Proform 500 LE Elliptical. Suddenly, why won't it turn on at all?
Check for a loose connection when plugging it in, verify that the main cable is connected to the console and the console also runs on batteries. You can try replacing those and use it that way with no adapter. They recommend alkaline batteries and if that still does not work, opening up your machine and verifying no cables are unattached or crimped would be best.
If you have any further questions please do not hesitate to contact us, i will be attaching a link to your manual also
888-713-2880
http://www.sportsmith.net/productsearch.aspx?dsNav=Nrc:id-772794-dynrank-disabled%7cid-750447-dynrank-disabled,N:773361
May 26, 2015 | Proform Exercise & Fitness
Proform elliptical
the cord could be coming loose during use or is bad
Aug 20, 2014 | Exercise & Fitness
Proform 500 le elliptical
I would suggest that there is a wiring fault or dry joint. you need someone who is tech savvy to check inside the head.
Jan 28, 2014 | Exercise & Fitness
Console isn't working
1) Adjust Reed Switch see the diagram, test it, clean it and tight the connector very well.
2) see if the fuse are o.k
3) tight the ribbon cable inside console board, and clean it.
4) see if the power goes on.
5) Replace batteries if your system ( have it) clean it the spring contacts battery for corrosion, oxide, etc.
Nov 18, 2013 | Exercise & Fitness
God bless yu
Jul 08, 2012 | Proform PFTL79807 - 850 W/ Gamefit...
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Just bought my Proform 490 LE elliptical 1 day ago and it has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried...
Mar 13, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
146 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
