Question about RTO Balboa, Heater w/Pressure Switch
Balboa Spa "LF" light flashing on Spa side Control Panel
We have an older Balboa Spa and have a "FL" flashing on the Control Panel, low flow thru both of the Pumps and the Heater will not come on. We have pulled the heating element and cleaned out as much of the lines as we can. Could the Pressure Switch be bad causing the Low Flow situation?
    Champion:
  • 305 Answers
Yes it is possible
Posted on Dec 05, 2013
2 Suggested Answers
adamh294
  • 310 Answers
SOURCE: just fitted 3.0 balboa heater
You can test the pressure switch using a multimeter. When the system is running (pumping water) the pressure switch should have voltage at both terminals, if the pump is on and there is only voltage on 1 terminal, you need a new pressure switch.
Posted on Apr 05, 2011
I have a Marquis Spa with Balboa Ins. Pak. I can turn the power off and back on and then hit the pump button on the control panel. The pump and heater comes on and it run displaying the temp. After some...
FL must be an Error code. It should be in your owner's manual,
No Manual? Try MFG website. or
try manualslib.com
This power stuff is dangerous.
Mar 25, 2015 | Pool & Spa
Hot tub flashing LF what does this mean
LF (or FL) usually means there is a water flow problem through the inline heater. If there is not enough water in the heater tube, sensors prevent the heater from coming on - so that it doesn't burn out. Depending on your spa, you could have an issue with the filter or your pump may not be operating properly. There are also two sensors, one at each end of the heater tube, that could be malfunctioning. Did you drain and refill the spa recently? If so, you could also have an air block.
Dec 22, 2014 | Washing Machines
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Balboa 52502 val 5m7
have you cleaned your filter recently. Sound like there may be a low flow error in low speed
either that or the start capacitor on your pump is bad and the pump will not come on in low speed unless you first give it a boost in high speed
anytime you ask for heat with insufficient flow there will be an error message
Jun 21, 2012 | Balboa Instruments Pool & Spa
My leisurerite spa pool is not heating up. It is displying LF
"LF" looks like "Low Flow" first thing I check is skimmer basket & filter to make sure thre are is nothing obstructing the flow
Sep 03, 2010 | Pool & Spa
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
RTO Balboa, Heater w/Pressure Switch Logo
128 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
