Question about Mitsubishi VS-5043 50" Rear Projection Television
TV - Mitsubishi VS-5043 50" Projection TV
This TV is about 11 years old and was working fine until... My son was playing XBOX and said there was a pop, the screen went blank and then the TV went dead. Have not been able to power it up since. Any help/advice you can offer would be greatly appreciated. Thank you Did the basic, power reset and checked the outlet all to no avail.
  • JFisch Oct 21, 2007
    We talked to several TV repair folks and they told us the cost to repair was not worth it for this type and age TV.  We ended up buying new and they took the old one away.  Have you had this particular set and were able to change fuses to repair?  Did not realize this was an option?
    Thank you for the reply.
Check the fuses
Posted on Oct 20, 2007
SOURCE:
Mitsubishi VS 360RA TV tuner
I've got one of those, too. Tuner's been out since 1997 from lightning storm. Tuner was not available then,not available now. It's an ancient beast-- you won't find parts for it--not worth $20, anyway.
Apr 20, 2010 | Televison & Video
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Completely black screen but has sound.
you probabily need to change the input, find the input button, when you hit it you should get a box on the screen, with inputs, highlight diferent ones and hit select- untill you get pick back, thats what my sugestion would be
Jan 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Aug 19, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi ws- 55807 clicking sound
My tv was working fine until now 8-9-08, it would not come on. The timer light comes on and goes off immediately.
Jul 20, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
60'' 11 year old Mitsubishi Projection TV
HELLO THERE WE ARE HAVING THE EXACT SAME PROBLEM. TURNS OUT THAT IT IS THE RELAY SWITCH mY TV IS ALSO 11 YEARS OLD. HAD THE SAME PROBLEM 4 YEARS AGO
Jan 17, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
