Question about M&S Systems DMC1CD 6-Disc CD Changer
I just ejected the (6) disc magazine from the DMC1CD changer unit and now the magazine will not lock back into the changer. Any thoughts?
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
Can not get the magazine to eject have a fuse but everytime i reset the fuse i get a little juice but then nothing, What fuse should be used on this unit and where is the manual eject/
you have to open the cd changer and you will notice that 2 or 3 disc move to the right side under the tray or on top
pusch them back into the cd magazine but don't force the unit and don't move the disc on the tray
now power it again and press eject
good luck
Nov 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
The system won't eject the CD changer.
You will need to reset your system.
Turn on the master unit and select the CD as your source. Open the door on the master unit to show all of the speaker numbers, here you will find a small pin hole next to the number 5 speaker. Use a small paper clip, unfold it and stick it into the reset hole. Hold the pin there for a minimum of 5 seconds until the clock starts to blink. Hit the time button seven times to get a solid time again. After turn on the master power and try the CD player again.
In my case the disc cartridge ejected when i was resetting the system.
Oct 26, 2010 | M&S Systems DMC1CD 6-Disc CD Changer
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
How do I reset CD changer?
I disconnected the car bettery for a minute, reconnected and was then able to eject the magazine.
Sep 29, 2008 | Sony CDX-T67 6-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
USA SPEC MERC99
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Sep 27, 2006 | USA Spec MERC99 6-Disc CD Changer
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
