Question about Garden
Victa carburetor problems
I have a 6 cylinder car carby fitted to a victa push mower, with reduction in air inlet & manifold sizes. mower starts ok no fuel supply problems but will only run on full choke. Any suggestions/solutions ?
  • 23 Answers
Why you have a car carburetor fitted to a mower troubles me... I think you'll find you don't gain any power increases by having such a large carbie on there, if anything you'll simply flood the engine with air or fuel and will have great difficulty maintaining a stoichiometric ratio.
The fact that the motor will only run on choke indicated that it is getting too much air without choke, and not enough fuel. This would be due to the intake size being still too large and probably a restriction in the venturi flow near the jets causing lack of suction to draw fuel from the bowl which would be due to the mower engine not creating the same vacuum as a car engine.
My honest suggestion?
Put a Victa carbie back on it, it's probably not going to work...
If you want it to run harder, adjust the throttle assembly to rev harder, or change the governor position.
Posted on Nov 19, 2013
steve_lima
  • 181 Answers
SOURCE: I have a Brigs&Straton 6.5 Quantum lawnmower will not stay running. I can keep it running by restricting the amount of air entering the carb with my finger (choking it) The mower will start if it
the problem is in your carb.,at the bottem of the carb. there is a bolt that threads in to the carb.pinch off the fuel line so that no fuel comes out after the fuel bowl is off the mower.now look into the bolt that you took off.there should be a hole oppisit the head of the bolt.there are also two holes that go through the sides.these holes are the fuel intake to the carb,the hole in the center is the fuel nozzle.most likely you have dirt blocking this hole and not letting the motor get enough fuel to run.thake some carb cleaner and spray it in the hole.take an air hose then blow the nozzle out.while you have the screw out take the bowl off and check to see if there is any water or dirt in the bowl.after cleaning.reinstall the bowl and start mower again.should be running ok now.if not let me know and i'll guide you through another fix.let me know if this helped or not................
Posted on Jun 02, 2009
#1 Taper
  • 1040 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
blown725
  • 15 Answers
SOURCE: My Honda 160 push mower starts and then runs rough
take off the bowl of carb....the main jet is clogged ....remove it with a screwdriver...a small piece of wire will work as something to clean it out.....clean the whole carb....fixed many of them...
Posted on Aug 24, 2009
  • 138 Answers
SOURCE: Mower starts, but dies immediately
that's not a choke lever, it's used as a speed control on some models. the two springs are attached to the governor rod, which is attached to an "air vane" governor - on these engines, you need to keep the gas tank fairly full at all times, the dip tube on the carburetor rides up off the bottom of the gas tank, if fuel level goes lower than this tube, it won't pull any gas to the intake - from your descriptions, though, it sounds like the diapragm between the carb and gas tank has "curled". briggs had a service flash on the problem and since it's new, you should take it to a shop that does briggs warranty work - it should be covered under warranty
Posted on Aug 28, 2009
SOURCE: mower engine backfires through air filter! will
A: Backfiring (and misfiring in general) can be caused by a large number of problems; unfortunately not only you do not even say what kind of Fulvia you have but your description of backfiring is superficial. You certainly have not attempted to exclude some obvious causes of backfiring. With these limitations I can only try to list a number of potential causes and how to solve them.
  1. None of the things you have done (plugs, cables, alternator, filters etc)has anything to do with backfiring. I am not surprised that no improvement was obtained.
  2. You must check that the valve timing is correct and that the timing chain has not jumped one tooth of the camshaft sprockets (details will depend on the car engine). Ensure also that the valve clearance is not badly out.
  3. You must check that the ignition timing is neither too advanced nor too retarded and that the correct dwell angle is set with respect to the points opening gap (details depend on the engine).
  4. It is unlikely that the problem is due to carburettor malfunction: however, check that the two carb floats are OK if everything else seems fine. I presume that by inspecting the spark plugs you concluded that the carb air/fuel mixture was basically correct.
  5. A leak in the intake system can cause backfiring but you do not even say if your car has a brake servo (some Fulvias did not have one). It is very unlikely that the servo is causing your problem since you would notice that a strong effort is needed to stop the car and that the same amount of brake pedal pressure can be applied with the engine running or switched off. It is possible, that the vacuuum hose running from the cylinder head to the servo (or its one-way valve) is damaged: a crack in the vacuum hose occurs very often although I have not seen it to produce symptoms as bad as the ones you describe. Any vacuum hose (with suitably rigid wall) of the same diameter will be OK to replace yours: it does not have to be a Lancia product.
  6. Your car may have a leak either in the carburettor rubber support or in the intake manifold gasket.
  7. I do not know if the Polonez servo can fit your Fulvia. Reconditioned servos can be obtained from commercial suppliers but I suspect that the servo itself is not the cause of your problem.
  8. Poor throttle response (when everything is tuned up correctly) can be due to failure of the centrifugal advance mechanism in the distributor (broken springs, stuck bob-weights etc) or to inefficient acceleration pumps (holed diaphragm) at the bottom of the carbs. However, neither of these problems should create backfiring.
  9. Fulvias do not necessarily start instantly from cold because, if the car has not been used for some time, the carbs must be primed, a process which takes a bit of time as the fuel pump works while the engine is spinning. Some people have fitted an electric fuel pump to prime the carbs. Of course, using the choke will help starting from cold.
Finally, it could well be that, after you have identified and cured the problem, you must balance and tune the carbs. It is easy to blame carburettors for all sorts of misfiring problems: in practice, they are very robust and long lasting but they should be balanced properly by measuring simultaneously the vacuum created by each carb pair at the appropriate plug hole in the intake manifold.
Posted on Apr 08, 2010
Starts fine and runs but why do rpms go up and down with some loss of power?
Could be the valve in the carby. Had a similar problem with my Victa. Have a look on the internet for briggs and Stratton engine carby service. It was really helpful. Your carby may be different but the info I found was very helpful and explains how the power valve operates and what to do to prevent surges and power loss.
Sep 17, 2015 | Toro Lawnmower 20099 Mower Mowers Lawn
My accelerator cable on my Victa V40 appears to be looser now so when I pull the cord off choke the revs no longer increase, how do I fix it?
hi.. the thottle cable has round end has poped out of its cam housing(gray plastic) inside the plastic carby... the only way to fix that is to remove the carby, but before you do clean your mower as you will create more issues if dirt/grass gets into the parts you will be working on...also take pictures before you start taking thing off, so you know how to reassemble it, as the carby will need to be taken apart....good luck
Jan 01, 2014 | Briggs & Stratton Garden
120cc stomp brand new engine backfires evry kick help
this sounds like a timing problem reset your timming if this still happens you inlet manifold may be letting in air it could also be the carby letting air in ,check these by running the bike and use some aero start around the fittings while running if it revs up abit then you have found it but ,take extreme care doing this as could result in fire ,you could take the manifold off and redo and carby but first try tighting all of it ,if you try the aero start it only needs small amounts but being a new motor i would go for tighting and undoing and retrying. hope this helps
Dec 22, 2013 | Motorcycles
New primer bulb but engine won't prime
remove and clean the carby. clean out the main jet. ensure that there is nothing stopping the primer circuit from working. There are two valves under the primer bulb and a spring. when you push in the bulb fuel is squirted into the manifold When you take your finger off the bulb the spring pushes it out and new fuel is drawn past a valve to fill under the bulb. Pushing in again closes that valve and opens a second valve which allows the fuel into the manifold again
Apr 26, 2013 | Garden
Victa ultima 207cc eng mod ult50 tecumseh starts runs for 15 sec then stops
it's in the carburetor. If it runs while being forced fuel then it means that the carb isn't supplying enough if any fuel for it to run on it's own. Take the carb apart as far as you can and make sure all the little orifices are clean
Dec 27, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Remove the carburetor on a 2005 harley davidson 883 sportster
REMOVAL
1WARNING
Turn the fuel supply valve to OFF and then remove the air cleaner and backplate, cut the clamp and disconnect the fuel hose from the fuel inlet fitting, detach the enrichener knob assembly from its bracket between the cylinder heads, disconnect the throttle cables from the carburetor, disconnect the fuel overflow/drain hose from the fuel overflow fitting, remove the enrichener cable assembly, enrichener valve and spring. (on California models only, disconnect the canister purge hose from the fitting on the carburetor body), remove the fuel tank and pull the carburetor free of the intake manifold. If removing the intake manifold, remove the four manifold mounting screws, remove the intake manifold, the seal ring, the mounting flanges and the two intake manifold seals. If removing the MAP sensor remove its screw, the MAP sensor clip and the MAP sensor itself.
Nov 02, 2012 | 2001 Harley Davidson FXD Dyna Super Glide
My ride on mower has started to leak petrol into the engine oil, fuel is gravity fed so I presume that it is seeping via the inlet valv, will an overhaul of the cylinder head complete with changing the...
Hi, no that is not the problem. The fuel is getting in through the inlet valve but it is caused by the needle and float in the carby not holding the gravity fed fuel pressure. It can be caused by a worn needle, incorrect float height or debris under the needle. Basically remove the carby,remove the float and needle, blow it out, check or replace the needle and make sure that when the needle is closed the float is sitting parallel with the carby body(holding the carby upside down with the needle and float assembled is the simplest way to check this). Also fitting an inline fuel tap will prevent this happening in future as the fuel leaks mainly when the mower is parked up. Hope this helps, regards Phil.
Aug 16, 2011 | Garden
My suzuki rm 250 starts and runs for a few seconds then stops . I have taken carb of and cleaned it out and seems to be fine. there is also a really good spark from plug.
First up, check all electrical connections are good, especially magneto wires exiting crankcase and CDI and coil. Check the continuity of the different phase wires with a circuit tester to be sure.
Disconnect the manifold from airbox to rear of carby, at least enough to put a flat piece of cardboard against back of carby throat inlet. Start, and if bike stays running, you have an obstructed air filter or airbox inlet.
If it still stops, then place the cardboard firmly across carby inlet and turn over engine with throttle open. There should be fuel visible on the card. If no fuel on the card, you have fuel delivery issues and likely cause is an obstruction in jets or float needle/seat. Check condition of fuel filter and fuel flow from tap also.
If you have fuel visible on the card you may have badly set air mixture screw (generally 1.5 turns out) the wrong sized jets fitted or a leak in the inlet manifold. Are the reeds in good condition?
Goodluck, cheers!
Nov 13, 2010 | Suzuki RM 250 Motorcycles
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Garden Logo
199 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
