Question about Sewing Machines
Janome js1022 The thread keeps breaking as I first starting to sew. I have changed bobbins,thread.
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
mohammed387
  • 1952 Answers
SOURCE: bobbin thread keeps breaking and bunching up
check ur bobbin holder
Posted on Dec 11, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
louislevel_2
  • 374 Answers
SOURCE: bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionc21dcd7.jpghave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
Posted on Apr 19, 2009
  • 240 Answers
SOURCE: top thread breaking during sewing.
Your top tension may be too tight or it could be incorrectly threaded. Check threading and ensure you are using a good quality thread. Cheap threads breaks without a reason!
Posted on Jun 11, 2009
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
My Janome 1600 keeps breaking threads
Is the tension too tight? Are the tension discs clean? Remove bobbin case, clean it and re-thread as this may be jammed.
Apr 26, 2015 | Janome 1600P-DB Mechanical Sewing Machine
My Janome keeps breaking its thread on both of my machines-Help!
Check that the needle is in the right way - usually with the flat side away from you, but check your manual. While you have the manual out check that the bobbin is turning the right way too. Hope you fix it
First - check to be sure you have the machine threaded correctly - if the upper thread path is wrong it will break the thread every time you try to sew.
Try this link for more info:
Sewing Machine Thread Keeps Breaking
Here is a useful document of this machine:
http://www.singerco.com/uploads/download/1300_533.pdf
Apr 13, 2015 | Janome Sewing Machines
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
Janome travel mate bobbin assembly
there could be something wrong with the hook and the hook race
or there could be a timing problem with the machine.
check to make sure the top thread doesn't come off the thread take
up lever when sewing
make sure the bobbin is turned the right way also.
Dec 05, 2012 | Janome Sewing Machines
Janome mylock 204d needle keeps breaking when sewing a rolled hem on sequined fabric
The needle thread breaks
May 16, 2012 | Janome Sewing Machines
Janome 2212
try changing needles-flat side to the back of the machine
check for any burrs around the needle plate area
check to make sure the tension is not to tight
check to make sure the bobbin is wound correctly & inserted correctly in the bobbin case
Mar 26, 2012 | Janome 2212 Sewing Machine
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
