Question about Stanley Tools TRE550 Electric Staple/Brad Nail Gun
Won't fire even when pressed hard against the material
  • 827 Answers
How old is this tool, if it is new take it back to where you bought it, most people try to repair them and get hurt in the process, if you have a repair center in your town take it to them and they will help you
Posted on Nov 24, 2013
What is the warranty on a Kindle Fire?
The Kindle Fire comes with a one-year limited warranty they warrant the device against defects in materials and workmanship under ordinary use from date of purchase.
Jan 15, 2017 | Amazon Kindle
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
How can i make my hitachi roof nailer shoot faster
I have seen roofers that can make the gun sound like machine gun. What they do is fine tune the adjustment on the safety foot up or down and slide the gun against the roofing material while bouncing the gun slightly instead of lifting the gun off the work while pulling the trigger. The safety foot should be pushed against work while sliding the gun from one side to the shingle to the other. The firing takes place when the gun is push down slightly, so that means that the adjustment has to be so the gun does not fire until you press down the final 1/16 to an inch or so. This action wears out the nose however due to rubbing against the shingle. One must balance the faster wear of the nose against greater productivity.
Feb 03, 2013 | Hitachi NV45AB2 Roofing Coil Nailer
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Mar 13, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
Does not shoot staple does this have lock out?
YES YOU DO HAVE TO PUSH IT TO THE WORK FOR IT TO SHOOT WENT WILL IT DO IF ANY THING
Nov 27, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
How do you load nails?
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft.
Flip the tool over on it’s back.
Insert the staples, (points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2010 | Stanley Tools TRE550 Electric Staple/Brad...
Don't know how to load stapler tre550
The staplesare NOT loaded on top of the pull out shaft; they are inserted directlyinto the slot that opens when you pull the shaft out. If the nose ofthe tool is not placed firmly against a surface, it will not fire.
CLICK HERE
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pullout the shaft.
Insert the staples,(points up) and then slide the shaft back in.
Nov 17, 2009 | Electric Stanley Tre500 Staple Gun /...
Stanley Tools TRE550 Electric Staple/Brad Nail Gun Logo
213 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
