Question about Akai SynthStation 49 iPhone Controller
Complete hard reset - Akai SynthStation 49 iPhone Controller
How to hard reset xtreme tablet
Hi Emani, to complete hard resetting of your Xtreme tablet, you have to hold the power button on / off along with volume button up / down simultaneously. Then only you get a menu in which you have to select the option for hard reset. Then, your tablet will complete get hard reset and go back to how you bought it.
Dec 13, 2014 | Tablets & eReaders
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
May 31, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
Coby not working
May 28, 2014 | Coby Tablets & eReaders
Hard reset motorola i880
Steps to Reset Phone Settings
This restores all the factory defaults, including the ringer types and display settings. The Recent Calls, Scheduler, and all text messages will be erased. Contacts are not affected.
  1. Press Menu > Settings > Advanced > Reset Defaults > Reset Settings.
  2. Enter six digit security code (default 000000) and press OK. (A disclaimer is displayed).
  3. Read the prompt and press Yes to complete the reset.
This resets phone settings and clears all phone data, including Contacts, History, Scheduler, and Messaging.
  1. Select Menu > Settings > Advanced > Reset Defaults > Reset All.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.*Disclaimer:Performing a master clear/master reset/hard reset will erase all your data (photos,videos,contacts etc) completely and reset all the settings to Factory default. The information contained in this website is for general information purposes only.In no event will resetcellphone.com be liable for any loss or damage including without limitation, indirect or consequential loss or damage. For complete disclaimer notice please visit Disclaimer. The brand names are the registered trademark of respective manufacturers.
Aug 29, 2012 | Motorola Cell Phones
Cant send text messages,just saves them to outbox
You should try a hard reset. Doing a hard reset will reset the item to factory settings. Please make sure you backup before performing the hard reset as the phone will be completely wiped. Once the reset has completed, you should be able to send messages. All you must do to reset is:
dial
* # 7730 *
Apr 08, 2011 | Nokia E72 Smartphone
Unlock code for samsung SGH-T509
*BEFORE COMPLETING A HARD RESET, BACKUP ANYTHING YOU HAVE STORED ON THE HANDSET, THIS INCLUDES CONTACTS*
To hard reset enter code *2767*3855#.
display_flip('id3183', 'divId3183');
1. Select MENU
2. Select Settings
3. Select RESET SETTINGS
4. Select ALL
5. Press OK
6. Press Reset
7. Enter Password (default 00000000)
thanks don't forget to rank it ok? thanks
Jul 12, 2010 | Samsung Lands Phones
How do you do a hard reset on a treo 650
1. Backup your data first.
2. While holding the red hang-up key, click the reset button. Keep holding the red key until after the progress bar completes and the Palm logo shows.
3. You are then asked if you are really sure - Pressing the up key at this point completes the hard reset.
Dec 18, 2008 | Palm Treo 650 Handheld
How to lock A samsung SGH-E590
Try This
1. Select MENU
2. Select Settings
4. Select ALL
5. Press OK
6. Press Reset
Nov 25, 2008 | Samsung SGH-R225m Phone
Akai SynthStation 49 iPhone Controller Logo
13 people viewed this question
Top Akai Audio Players & Recorders Experts
Michael Harrier
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
