Does not load fast - Computers & Internet
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Won't spin fast when fully loaded
You may have a weak clutch. If you can stop the washer during spin by hand, that's what it is.
Jan 26, 2014 | Kenmore 24422 Top Load Washer
Generator vertex 5500 11.0 tecumeseh OHV, runs fast and slow.
i have the same problem. i think i have a bad bearing in the generator.
Mar 04, 2013 | Electrical Supplies
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Videos have to load alot while watching
The one that you are experiencing is actually not a problem. YouTube relies on the speed of your internet connection. If you have good speed, it will load or buffer fast. The format and quality of the video that you are watching also affects how fast it will load.
For best results, try getting high-speed internet.
Hope this helps! :D
Sep 08, 2010 | YouTube Videos
Washer is not spinning fast. It spins just not fast enough to get the water out of the clothes.
Most washers have a speed limiter in them to prevent the unit from damaging itself "IF" it is severely out of balance. Your solution is to redistribute the load, so it will not be out of balance and/or wash smaller loads so the machine can redistribute the load itself.
Hope this helps..
Kindly,
Jim
Dec 21, 2009 | Frigidaire FTF530FS Front Load Washer
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
Jan 07, 2009 | GE WSXH208A Front Load Washer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
