Question about Echo Backpack Blower PB-500T
Throttle handle trigger is stuck - Echo Backpack Blower PB-500T
All three of my echo trigger got stuck, hard to pull. Was sticking carb linkage, not kinked cables. Luned, worked, lubed till freer.
Posted on Jul 26, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
See if the linkage on the carburetor is stuck
Posted on Dec 29, 2013
Spray trigger stuck?
Hi there! If the spray trigger is stuck try removing and replacing the handle. Remove the two screws that attach the handle. Slide the handle off. Inspect the two rods inside of the handle for damages. Make sure both rods are pulled down. Replace handle and two screws. If the spray trigger is still stuck or if the rods were damaged in any way a replacement handle may be needed. If so I have included a link where you may purchase a replacement handle. Search Results Good luck!
Aug 07, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
How do I reconnect ,my throttle trigger for ms 260
remove the top cover on the handle, there is a screw in the bottom of the handle end. put the on off switch in the choke position all the way down, connect rod to throttle on carburetor then slip it into the hole in the trigger. replace operator presence lever making sure the spring is in the notch on the side of it, while holding it in place reinstall the top cover.
Jun 13, 2012 | Stihl 024 026 Ms240 Ms260 Throttle Trigger
The fast idle button on my Poulan 2050 is stuck down all the time. I assume it should pop up and lock into place when depressed. I can get a total replacement part, with pins, no problem. How do I...
The trigger and lock out lever comes as a kit, part no. 530071305, remove the top cover, depress the trigger and pry up the throttle wire away from the trigger, knock out the two roll pins, drop the trigger out of the bottom of the handle, lift the throttle lock out of the top of the handle.
Oct 27, 2011 | Garden
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and...
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Jul 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
Model P3314 throttle is stuck
Remove the air cleaner assembly to see the carburetor throttle mechanism and open the handle so that you can access the throttle trigger. There should be either a cable or wire connecting the trigger to the throttle arm on the carburetor. Try moving the trigger and see if it responds at the carburetor. Is the carburetor arm against the idle stop screw, wide open, or some where in between? There should be a spring at the throttle arm that returns the arm to the idle stop if the cable/wire is disconnected. The trigger mechanism may be jammed with sawdust to prevent movement. Hope this helps!
Mar 19, 2010 | Poulan Garden
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Echo Backpack Blower PB-500T Logo
442 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
