Question about XO Vision Tablets & eReaders
Restart button
Red light stays on and no green light seems dead but charged overnight
  • XO Vision Master
  • 2,072 Answers
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Posted on Nov 19, 2013
After charging overnight I only have a white screen when I switch it on
Try this suggestion rom Amazon:
Restart your Kindle Paperwhite
Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart.
Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Sep 07, 2016 | Amazon Kindle Paperwhite
Kindle fire won't turn on - even after full charge
Press power and volume+ button together until reset screen appears!
Jan 17, 2015 | Tablets & eReaders
There is a red and green light on my irulu tablet when charging and wont turn on
Some tablet you have to hold the powe'd button for at least five seconds.If that don't work it's dead.
Jan 16, 2015 | Tablets & eReaders
I can not get get to the first screen on my nextbook, it is charge and it stays totally black
I am not directly familiar with your particular tablet, but try this.
Locate the reset button's access hole - usually a tiny hole either on the back of the tablet or on the edge near the various ports and connectors. If you have a manual for the Tablet, it should tell you the location of the Reset button.
  • Press the button by inserting a paperclip or similar GENTLY into the hole. PLEASE MAKE SURE IT'S NOT THE MICROPHONE HOLE YOU"RE LOOKING AT.
  • You should feel a soft click when the recessed 'Reset' button is depressed. Hold it down for about 10 seconds, after which the Tablet should reboot itself, and hopefully will now run normally again.
  • Note that you WILL NOT lose any data or settings by resetting your Tablet this way - it merely restarts the microprocessor which may have frozen.
Dec 30, 2014 | Nextbook Tablets & eReaders
How do you know when Kendle fire battery is dead
If this is a first generation Kindle Fire, then you are in good company, and the problem may not be the battery itself (which is good, b/c the battery is not user replaceable, at least for non-techies). Refusal to charge is apparently a very common problem, which seems to have multiple contributing factors. The charging port sometimes gets 'loose' or dirty, so I would suggest trying that first. Vacuum or blow out any dust/dirt, then look at it under a bright light and perhaps with a magnifying glass to see whether any portion is bent or twisted. If all looks OK, then I would try plugging it in and gently moving the cable around a bit to see whether the charge light goes on and off. If so, you might be able to still charge it by 'propping' the cable to gently nudge it in the direction that causes it to connect. This is a relatively short-term solution, as it will eventually stop working. Another problem seems to be in the 'programming' inside the Kindle, such that, under certain conditions, even with a good charger and cable, it will not take a charge. A common trick, when this seems to be the case, is to ensure that it has fully shut down before trying to charge. For some reason, if it is fully shut down, it is more likely to 'accept' a charge. Push the power button (with the charge cable unplugged) and hold it for at least 20 seconds. After that, it should be fully shut down. Then connect the cable and look for the orange light. If you get it, then leave it alone (verify it stays on when you lay it down, and 'prop' as needed) and preferably leave it to charge all day or all night, or until you see the charge light has turned green. If none of that is successful, and especially if you cannot get the charging light to come on no matter what you do, then try a new cable (cheap ones won't do) and/or a new charger. Borrow from a good friend for a cheap test. We just gave up on ours, after several months of nursing it along using various methods. It is a shame, because the device (except for weight and thickness) has been fantastic for my wife and then my daughter. I hope you manage to get a lot more time from yours!
Jul 16, 2014 | Amazon Kindle Model D00901 Tablet Reader...
Purchased a new tablet and after charging the unit overnight I turned it on and all I get is a blank screen. Its a pretige10 visual land tablet
Can 't go to settings I don't have a screen on. And I won,t, it won't even right up. I can,t even tell if the battery is charged. Its just dead in the water as they say. Anyt thoughts or. Am I going to have to send it back for repair?????
Nov 04, 2012 | Visual Land ME-110-16GB-RED - Prestige 10...
My kindle will not turn off. I can't get it to do anything.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still doesn't respond, do a hard reset by holding the power switch for 15 seconds
Jan 27, 2011 | Amazon Kindle Wireless Reading Device
We purchased the coby kyros touchscreen internet tablet-MID7015. we are trying to charge it but there is no light that is coming on to say whether it is charging or not. The internet says there should be a...
At the very bottom of the device beside the USB port if you look inside when it is plugged in, you will see a little red light come on. I charged mine overnight for approx 6-8 hours and when I looked, the light was off and the device was charged.
Dec 22, 2010 | Tablets & eReaders
Tablets & eReaders Logo
Top XO Vision Tablets & eReaders Experts
Are you a XO Vision Tablet and eReader Expert? Answer questions, earn points and help others
