Question about ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip Cortex A8 Android 4.0, 4GB
I can't get into my tablet because the screen is too dark.
The screen setting is on darkest mode. I'm trying to change it to brighter but can't see to change it. I tried to access it through my pc but that is not working either. Does anyone know how I can fix this? Thank you.
  • ZEEPAD Master
  • 2,072 Answers
Flash light. :)
Posted on Nov 19, 2013
Screen too dark
go into settings and look for personalisation the change your background if that dosent work its probably on night mode or you have it on auto set
Aug 31, 2016 | Acer ICONIA B1-710-83171G00nw 8 GB Tablet...
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
Jun 21, 2014 | Tablets & eReaders
My android jelly stays on a dark screen that says android and i reset it already
Start with tablet off. Hold power and volume up. You should boot into safe/repair mode. Try some of the options in there to get your tablet going again.
Jun 03, 2014 | Visual Land Prestige 7L Android 4.1 Jelly...
Wifi Being disabled while in sleep/screen time out mode.
don't know if it works the same for your tablet as it does my droid phone, but i had to go into my settings/battery and data management/data delivery/social applications/data delivery frequency and select automatic(push). I'm sure its in a different location and probably named something else on your but i would start by going through your setting and seeing if there is something in there you can change.
Feb 06, 2014 | Samsung Galaxy Tab Tablet PC
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
The screen turned off and it wont turn back on!!!
The symptom you described may be due to the main battery being discharged. In many tablets, there are 2 batteries, one main and one used to keep memory intact during suspend mode. When the unit powers on, it turns on the backlight (probably the highest power drain of anything on the tablet) so you can see the icons on the screen. If the main battery doesn't have enough energy, the sense logic will put the machine back into suspend mode, and it will appear to go off. You should plug your charger in, and see if this fixes the problem. If it doesn't then you need to check the voltage of the charger with a meter. If you don't have a meter, you can buy then at Harbor Freight for around $5. With the meter on, and the charger plugged in, stick the red lead of the meter in the center hole, and touch the black lead to the barrel of the power connector from the charger, and you should read some volts. The charger should say on it somewhere it's output voltage. Hopefully you've marked your charger with what device it goes to because many chargers look the same and have the same power connector but are not in fact the same.
Making the screen brighter uses more energy. So if you were successful with your "sun" icon, you could have made the problem worse.
Nov 27, 2017 | Google Android 4.0 7 inch 1080P Video...
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip Cortex A8 Android 4.0, 4GB Logo
Top ZEEPAD Tablets & eReaders Experts
Frank Russell
Frank Russell
Vladimir Frolov
Tom Chichester
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
