Question about Frigidaire FES367 Electric Kitchen Range
How do I change an element from my stove which is a deluxe 234 model..very old stove but goe's well
    New Friend:
  • 20 Answers
Unplug the range from the wall first. Just raise the cook top and the elements are attached to the bottom of it, probably by four screws. Note how the wires are plugged in then unplug them, unscrew the element that don't work, screw the new one in plug the wires back and put the cook top back down. The wires should have blade connectors to easily unplug and replug.
Posted on Nov 22, 2013
2 Suggested Answers
watugot
  • 290 Answers
SOURCE: Element Problem
I believe the range you have has a relay board mounted on the rear of the unit. The element switches tell the relay board when to turn the element on and off. You probably have a stuck relay on this board.
This type of set-up is fairly new and not a whole lot of people have worked on them. They will throw a good repairman for a loop the first time he tries to diagnose one.
(I speak from experience)
Posted on Oct 27, 2007
Elements does not heat up but the oven slowly does... The numbers go back to100 then slowly goes up but does not get hot
how old is this stove
slow stove means an expensive service
first
faulty thermostat
replace the elements
oven door seal
second
the dials
May 29, 2016 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I need a bottom element for a general electric stove (deluxe model) built in 1952. I also would like to get a manual if there is one out there. This stove has been used in the summer only since 1966 and I...
If you know the model number of the stove. Go to Repair Clinic.com web site. Type in the model number, all available parts for that model number will be displayed. You can also call them on thier 800 number. i have used this site many times and found the people very helpful.
Mar 31, 2011 | Ovens
Where are the bottom elements located on a kenmore electric stove c880 type 30s..
They are under the oven cavity. The Built in elements are considered a deluxe feature. In case it needs to be changed depending of the manufacturer ( Kenmore is only a name and many suppliers build product that are rebranded Kenmore ) the element is accessible through the right or left side. In case it needs to be changed you can remove the side panel and slide the baking element out to change itr
Mar 14, 2011 | Kitchen Ranges
I have a kelvinator De Ville deluxe eye level stove. The top oven does not heat up. I expect a fuse is blown. Where is the fuse box?
Check you heating element for blisters or cracks the elements are usually the first to go, if not a wire may have burnt off the backas far as a fuse not knowing model no. i would say there is none unless it is digitally controlled
Mar 12, 2011 | Vacuums
How to change cooking element on top of stove. is there a detail drawing and manual stove is 4 year old
Electric stove top? Is the element a coil or soild element? Or is it a glass top?
Feb 07, 2011 | Ovens
Preheat not working in oven
When the element went it also took out the contactor..
Check out this tip...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Apr 10, 2010 | Ovens
This stove is about 35 years, works good but the lower element went so I installed another but the preheat won't work and the element stays on totally. Kenmore Deluxe Self Cleaning model # c968-92622
Hi,I think you have enjoyed a good value for your money on your stove,but nevertheless,i think your unit deserves a genaral servicing,which can only be done by a qualified technician in your area.
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
Frigidaire FES367 Electric Kitchen Range Logo
76 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
