Question about GE Profile WPRE6100G Top Load Washer
Load size dial on washer spins freely instead of moving to setting
When setting the load size dial (options range from small to super capacity, with reset option), dial now spins freely in both directions so that I am unable to select a setting. I usually hear a sort of fast clicking (for lack of a better word) noise as the knob turns), but now that noise is no longer there. This dial is supposed to turn without pulling the knob out or pushing it in. It seems as if there is no resistance, as if the "cogs" are no longer there to turn the wheel, although there was no indication that they might be wearing away, since the previous time I used the machine it worked fine. The machine is 7 years old, and is used approximately once a week, usually on the medium size, delicate, cold water setting. I think it is stuck on the small or smedium capacity setting.
  • GE Master
  • 16,973 Answers
That setting has to do with how much water is let into the drum. You can get a new switch for that. If you post the model number.
Posted on Nov 18, 2013
Testimonial: "I know what the setting does, that's why it's called the load size dial, which is what I stated in my question post! What I want/need to know is how can I fix it, if it is possible for me to do so."
  • 2 more comments
  • emme baker Nov 19, 2013
    I also included the model of the washing machine - GE Profile WPRE6100G
  • Brad Brown Nov 19, 2013
    https://www.partstore.com/Model/General+...
    Brad - Knowing where to get the part is not really going to help me much if I don't know which part I need to replace or how to get to it, or even what exactly the problem is. I really need to discover the problem and find out if this is something that I can fix myself before I order parts. Can you please explain what the problem is (if you do know), and how I go about fixing it, instead of just giving me a web address for a part. Thanks.
    I was trying to keep it simple for you. You could call a repair person and pay several hundred dollars to have this done but seeing that you appear to want to repair it yourself, you need to unplug the washer and disconnect the water hoses. Pull it away from the wall, look at the back of the machine to see if there is a panel that comes off behind the controls. If the whole back is one piece, you may want to see if there are screws in the front, on the top, that hold the control housing to the main part, take the control housing that runs the whole length of the machine loose and you should be able to see the back of the control board. There are electrical connectors on it that you have to remove and also screws that hold it in. Take those out. You may want to use a camera to take pictures as you go so that you can tell where things are when you put it back. The part is WH12X10405 and it costs 100 - 150 USD.
4 Suggested Answers
SOURCE: GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Posted on Nov 04, 2009
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
SOURCE: The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
Posted on May 04, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My washer wont turn on at all, wont fill up,spin or rinse on any setting
it sounds to me the lid switch problem. when it fails nothing works on some models
Dec 27, 2015 | Westinghouse WWS833ES Super Capacity Top...
Dial won't set
you can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Nov 19, 2013 | GE Profile WPRE6100G Top Load Washer
Load size dial won't set anymore, just spins freely
Most likely the knob is defective, order a new one.
Apr 25, 2017 | GE Profile WPRE6100G Top Load Washer
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I want whirlphool whasing machine with dryer please give the gideline of it and its price my e - mail ID is sabiha_1993@hotmail.com.
Washers are more advanced and stylish than ever before. When you're buying a washer, look for features that make washing easier and more efficient, less costly, and kinder to fabrics. Thanks to advances in technology, it's all possible - and our washer buying guide shows you how.
Washer Types
Feature options, capacity, energy use and style are all factors to consider when deciding between a front- or top-loading washer.
oth top-loading and front-loading washing machines will do a good job of cleaning your clothes. The most significant differences between these types of washers are capacity, energy efficiency, water use, feature options, and style.
Top-loading machines
Traditional top-loading washing machines are available in a wide assortment of models, price ranges and styles. The most basic top-loading washers perform very well and are generally a good value for a no-frills, clean wash. Other top-loaders offer more cycle and temperature selections, spin speeds, and fabric care extras as they increase in price. Overall, top-loading washers are generally less expensive to purchase than front-loading machines, but are slightly more costly to run because they use more water and electricity.
Most top-loaders fill the tub with enough water to cover the clothing, then agitate them to get the clothing clean. Some manufacturers now offer high-efficiency top-loading washers using a number of different technologies. One such technology is the Whirlpool® Calypso® wash plate. Instead of agitating fabrics to get them clean, the wash plate moves them through a shower of concentrated detergent and water. The action is gentler on fabrics; it's designed to provide better cleaning with far less stress to garment fibers. And with the agitator out of the way, the washer has more room to clean bulky items such as comforters and rugs.
Standard capacity for a top-loading washing machine is 12 to 16 pounds per load. The Calypso wash plate model can hold up to 18 pounds of laundry (think the equivalent of 16 pairs of jeans).
Here is a link to some Whirlpool washers for you to look over.
Dec 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Won't spin heavy loads
you need a new transmission it will slowly get worse until it stops working
Dec 23, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer won't move into spin phase on the Regular Cycle setting.
Have you checked the lid switch??? This will prevent it from spinning look on the lid you will see a plunger.. watch where it goes down to you can use a pen to press the sw while the lid is up to see if it is working ...PS: dont forget to set it into the spin cycle first..let me know what happens
Feb 16, 2008 | Whirlpool LSR6232J Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
172 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
