Question about Stanley Bostitch N12 Nailer Oring Kit Ktbo912
100294 cylinder seal CN 31425 exhaust valve bumperneed parts
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
2004 Kawasaki KX 125 leaking oil from the muffler
Hi, Anonymous and the usual suspects are:
1. Engine oil system overfilled.
2. Piston rings worn past service specs.
3. Broken piston rings.
4. Piston pin retaining clip failure.
5. Cracked piston.
6. Broken piston ring lands.
7. Hole in the piston.
8. Valve/guide clearance worn past service specs.
9. Worn out valve seals.
10. Crushed or loose valve seal.
11. Gouges in cylinder walls.
12. Cracked cylinder or head.
13. Blown head gasket.
14. Crankcase breather blocked or hose pinched.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Kx 125 Oil coming out of exhaust ALOT
Oil Dripping THICK from muffler exhaust connection
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX125-KX250-Service-Manual-Repair-1999-2000-2001-2002-99924-1244-04.pdf
OEM Parts for Kawasaki
2004 Kawasaki KX125 Owner Manual
Aug 14, 2013 | 2004 kawasaki KX 125
I have a TMX 155 bike,but so much smoke out of the exhaust
Is your cylinder block been rebore from standard to 0.25? Did you used genuine Honda Parts? Honda's are very fussy on parts and cost more when you buy genuine parts. Recheck the cylinder block if there is excessive scouring marks in the bore and make sure it bored properly by a trusted machinist. Check the valve guides as well and replace the valve seals again if necessary.
Dec 29, 2012 | Computers & Internet
Air leaking/cn-350b
Usually caused by poppet seal # cn-220-3. Poppet seal will crack and not seal fully. New seal must be heated to install or you could crack it. I use heat gun or hair dryer. Examine old seal for proper orientation of taper. Good luck with your repair
Sep 19, 2012 | Air Tools & Compressors
Mastercraft framing nailer
Most likely a bad head valve o-ring or seal where the head valve seals to the cylinder. Could be a few other things too like a worn head casting but not near as common. I have no idea where you would get parts for it.
May 18, 2012 | Air Tools & Compressors
Pw80 oil coming out the exhaust
1. Engine oil over filled.
5. Cracked piston.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
HELP have oil coming out of my PW80 Exhaust
Excess oil out exhaust pipe
YAMAHA PW80 Owner Service Manual
OEM parts for Yamaha
YAMAHA PW80 Owner Manual
Apr 20, 2012 | 2004 Yamaha PW 80
My hitach nr83a just blows air out the exhaust when pluged in and wont shoot. is this a trigger or exhaust problem ???
Your problem is most likely where the cylinder / head come together. In the Hitachi framers, the cylinder is designed to move up and down (unlike Bostitch where the head valve moves) so if the O-rings are dirty or broken, or the spring under the cylinder is broken - the cylinder won't make a good seal to the head valve.
You can try plugging the tool in and giving a couple of firm taps straight down on the head with a rubber mallet - if the leak stops or slows you'll know the problem is with the cylinder movement.
Check the head valve seal - often they get sand / debris embedded in them which prevents the cylinder from making a good seal.
It is rare for a Hitachi trigger to be a problem.
Nov 24, 2011 | Hitachi Nr83a- Strip Nailer-driver Blade...
1985 Honda GL 1200 Aspencade Gold Wing oil in my exhaust pipe what is the problem?
Hi, Rudy and the usual suspects are:
5. Cracked piston.
heavy white smoke from exhaust GL1200 Information Questions goldwingdocs...
1986 GL1200 Oil in exhaust
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Oct 03, 2011 | 1985 Honda GL 1200 Aspencade Gold Wing
2003 Honda CR 250 R oil leaking front of the exhaust pipe
5. Cracked piston.
2003 cr250r exhaust leak at exhaust port
Need help trying to reduce excess spoge 2002 CR250R
CR250 2002 2003 pdf
Honda CR250R Owner Manual Competition Handbook
May 20, 2010 | 2003 Honda CR 250 R
Oil on sprark plugs
  1. Disconnect the negative battery terminal.
  2. Remove the valve cover, using the proper procedures.
  3. Remove the camshaft, shims and rockers, if equipped, using the proper procedures.
  4. Remove the spark plugs.
  5. Rotate the engine to Top Dead Center (TDC) for each cylinder's seals that are being replaced; e.g., if replacing the No. 2 cylinder valve seals, have the No. 2 cylinder at TDC. Use a coat hanger put down into the cylinder to determine when it is at TDC.
  6. Attach a fixture at the flywheel or the front of the engine to prevent the engine from rotating. Make sure the fixture damages no components.
  7. Thread an adapter into the spark plug holes that can be hooked up to a shop compressor air hose.
  8. Apply 90 psi of shop compressor air to the adapter hose. This is done to keep the valves from dropping down into the cylinder when the valve springs are removed.
CAUTIONTo avoid personal injury, wear eye and ear protection. Keep hands and clothing away from engine parts that rotate, in case the engine does rotate from the cylinder air pressure.
  1. With the cylinder under pressure, remove the valve spring retainer and the spring, using a spring compressor tool. Hitting the spring retainer with a soft hammer may help loosen the valve keepers, if the keeper will not move downward when trying to compress the spring.
  2. With the valve spring removed, remove the oil seal.
To Install:
  1. Install a new seal, using Toyota Special Service Tool (SST) 09201-41020, or equivalent.
  2. Reinstall the valve springs (See Valves).
  3. Release the air pressure and reverse the removal procedures to complete installation.
  4. Connect the negative battery terminal, start the engine and check for leaks.
0900c15280046373.jpgFig. 1 Removing the valve sealsCelica 0900c15280046378.jpgFig. 2 Intake and exhaust valve sealsCelica 0900c15280046379.jpgFig. 3 Installing the valve sealsCelicaWith Cylinder Head Off Engine
  2. Remove the cylinder head, using the proper procedures.
  3. Remove the valve and spring (See Valves).
  4. Remove the oil seal.
To Install:
  2. Reinstall the removed components to complete installation.
  3. Connect the negative battery terminal, start the engine and check for leaks.
Aug 25, 2008 | 1990 Toyota Celica
Stanley Bostitch N12 Nailer Oring Kit  Ktbo912 Logo
57 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
