Question about Coby 4GB Kyros MID8048 8" Tablet Black
Need to update coby mid8048 - Coby 4GB Kyros MID8048 8" Tablet Black
Is there anything I can do to improve the Cobt Kyros mid8048? I can't afford another Tablet, how do I get the best service under circumtance?
I have one of these tablets, but I don't use it anymore because it's too out of date, and the battery dies as soon as it's disconnected from power. You should try to find an updated version of Android OS, but not too recent, and install it. You also need to make sure you know the processor type and whether it's compatible with the OS. Once you do that, you can try to download apps from the Google Play Store, but you may have better luck with a non-google source like GetJar. Always beware of malware takeover attempts. I recommend a good anti-malware app like Kaspersky.
Feb 11, 2017 | Tablets & eReaders
My coby mid8048 won't load past the Android screen, is there a solution for this problem.
This is the most common problem with tablets - there are literally hundreds of people asking the same question and i have had the same problem myself - its usually corrupt bootloader or OS and can be a nightmare to repair.
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up. Its actually a disgrace and I have been repairing computers and latterly tablets for the last 30 years and it is by far the most common issue with any tablet except Apple - there is a reason they are so expensive - lol
May 12, 2014 | Tablets & eReaders
Update coby kyros mid8048
there are no official updates for this tablet, if there were, it would be on cobyusa.com
Apr 14, 2013 | Coby 4GB Kyros MID8048 8" Tablet Black
I forgot my password to my Coby Kyros mid8048 i was wondering how you could reset it please help me
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 12, 2013 | Coby 4GB Kyros MID8048 8" Tablet Black
Need instruction model for coby kyros model md8048
Assuming you mean the Coby MID8048, you may download a copy of the manual here.
Jan 02, 2013 | Coby Kyros 716829701508 Tablet PC
I need to download driver software for my coby kyros MID7015 so i can sync it to my pc
i have coby kyros mid7010-4g tablet
it just load the coby logo then penguin logo then android_ text
i tried the factory rest ( power + back + home ) ..
it gives " Unexpected updater mode! Please reboot your device.
How do i proceed from here Any help please.
Mar 20, 2011 | Coby Kyros 716829701508 Tablet PC
Coby 4GB Kyros MID8048 8" Tablet Black Logo
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
