Question about KitchenAid KGSA906PSS Gas Kitchen Range
Tappan series 110 the igniter is glowing but it wont lite the oven
  • 26 Answers
Is the gas turned on at the stop valve behind the range? Assuming the gas is on, the igniter can glow but not actually be working properly such that the control valve does not open or the valve may be failed. There are electrical measurements for the valve and igniter and related circuit that can be made if you have a clamp on amp meter and a volt meter.
Posted on Nov 20, 2013
3 Suggested Answers
SOURCE: Broiler not lighting on gas Kitchen Aid SuperBa
I had the same problem with the igniter glowing and I could smell gas no flame. I took the broiler out.
Not as hard as it sounds. Took out 6 screws I did not have to disconnect the igniter, because there is
enough slack in wire to just drop it down a bit. Looking where the burner tube came out I could see
the orifice. I connected a safety pin tin long twisses and stuck the pin into orifice rubbed it a bit. Put it all back together. Just make sure the burner tube gets set in all the way don't force it.
Good Luck Joe C.
Posted on May 06, 2009
SOURCE: igniter does glow and oven does not heat
Had same problem come up on christmas cold turkey yuk! What i did was swap the upper igniter for the broiler with the lower igniter for the oven and it worked so it sounds like the problem is the igniter you can do what i did to buy some time or just swap out the igniter with a new one. Good Luck
Posted on Dec 26, 2010
The stovetop of my Tappan series 110 works, but the oven won't. What do I do?
if the oven wont fire up, 90% chance you have a glow rod failure, this is like a pilot lite
call a local service company.
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Tappan MPF500PBW Gas Kitchen Range
Oven will not lite maybe glow ignitor
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Glow plug on oven
Yes. Igniter stays on from just before ignition until just prior to burner shut down with each burn cycle.
Nov 12, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Feb 04, 2008 | Kitchen Ranges
Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Feb 01, 2008 | Tappan TGF363 Gas Kitchen Range
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
223 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
