Question about Vector Vec143 Bright Bar Work Light
Looking for replacement charger
Lost charger
Lost my charger Hi I lost my Fitbit charger is
I think so far ebay is the only way. We help you from losing the actual device though. Featured Products
Aug 06, 2013 | Fitbit Flex, Set of 3 Swappable Wristbands
Lost the wall charger for the Vector 450amp Jump start system and can't charge it. Help! need to find replacement Dayton ,Ohio
you can use just about any wall charger. like a house phone charger or a roaid charger. but look at the INPUT on your jump it should be 12 VDC and fine one that is 12VDC OUTPUT and that it.
I hope i could help you
Dec 28, 2010 | JUMP START SYSTEM
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
I lost my Philips Coolskin 7775X shaver charger.
philips norelco 4222-039-10972 adapter charging cord for electric shaver norelco 7775x power cord replacement parts.
Oct 23, 2009 | Philips Health & Beauty
Would like to know model # for charger for a sanyo vpc-t700 camera. I lost my charger and need to find a replacement charger that came with the camrea. That is why I need model #. Please Help Jon
I have the same problem. Sanyo advised this charger is no longer made. Other than eBay, Radio Shack has charger that will work with the battery in the VPC-T700 and priced at $30. Walmart has a universal charger for numerous devises with varying connections, also priced at $30. I did not try the Walmart option; however, the packaging does list Sanyo products are compatable.
Sep 17, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Lost the charger for mustek dv 4000 model where can i get replace
United Kingdom :
Hotline: 0870-0132017
E-mail: support-uk@mustek.eu
Monday till Friday, between 9:00 AM and 17:30 PM
but to be honest best thing to do is look by the charging point will have the voltage and ampage inputs to charge get a charger that matches those inputs if i remeber correctly (i used to work in the service center for mustek) the old fatter nokia chargers work in this to charge it
Aug 28, 2009 | Mustek DV4000 Memory Card Camcorder
Lost jet clean charger for philips architiect
Hi, it may be worth your while looking at e-bay to see if anybody is selling a broken shaver with all the bits still working, You can usually pick things up that way, plus, they are often Very cheap! Best of luck, Nick.
Nov 09, 2008 | Norelco Arcitec Electric Shaver with Jet...
Lost the charger for T5720 cradel, need voltage specs for replacement
HI,
The charger cradle for this model is 220V.
Hope this helps
May 24, 2008 | Motorola Talkabout T5720 (7 Channels)...
Vector Vec143 Bright Bar Work Light Logo
60 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
