Question about BALLARINI COOKWARE Home
On a 10 inch fry pan the feflon coating is coming off, at this point would want an exchange of a pan that is usable
5 Suggested Answers
  • 473 Answers
SOURCE: I purchased the set of
Look Carefuly under or handle for number factory anything can identified those pan Then From QVC.com check for service repair then fill up the form for order.. Good Luck
Posted on Sep 30, 2010
joeguest2
  • 2080 Answers
SOURCE: Is it possible to restore
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Posted on Jun 12, 2011
  • 17328 Answers
SOURCE: breville toaster oven non stick pizza pan coating coming off
f you want to have a non stick coating you will have to order a new pan. There is no way to get a coating like that to stick again or even repair it. You might also want to scrape it off and go back to the old school method of greasing the pan.
Posted on Aug 10, 2012
  • 51268 Answers
SOURCE: My Farberware310-A fry pan has a sticky surface that every thing I fry in it sticks to the point of uselessness. Any suggestions?
junk it and get a different brand
Posted on Aug 01, 2016
I have pots & frying pans cook essentials. All nonstick is coming off. Life time warranty. How do I return?
contact the manufacturer for the warranty claim process
non stick always comes off after around 1 year and is normally a useless coating after 2 years
Nov 20, 2017 | Kitchen Appliances - Others
I dropped my frying pan because i forgot the handle was hot. I am deverstated because there is now a big dent in the side. can it be repaired
In most cases no, the metal is not sturdy enough to be straightened and there is no form that you can use to hold it steady. Also if it has a coating on it like Teflon, you risk scaring the coating or making it come unbonded from the metal..
Oct 21, 2016 | Cars & Trucks
Peeling nonstick coating
It can't be fixed. In the future, use only plastic cooking utensils so they won't scratch off the non stick coating. You can line the pan with foil if it is a baking pan, if it's a frying pan, there's no fixing it.
Apr 07, 2014 | KitchenAid 16-Inch by 13.5-Inch Roaster...
Sticky black handles on Farberware frying pan
I tried the grease cutting soap to no avail. Decided it needed a more aggressive approach. Since the suggested cause was grease, I decided to try my automotive brake cleaning spray. That did not wash the surface but it did soften the surface enough to discover the culprit was a deteriorated coating Farberware put on the handle. The brake cleaner was effective in softening the coating such that I could use my finger nail to scrap it off. I now have a smooth non sticky handle.
Nov 24, 2013 | Home
What is the difference between cooking with a frying pan and using a wok to make stir fry.
A carbon-steel wok will give better results than a frying pan if you want to make a good stir fry. Not just from a taste point of view but also because it's much easier to flip the food around in a wok. In a frying pan it just shifts it to the other side and a key point of stir fry cooking is the movement.
Feb 18, 2013 | Home
What are frying pans made out of?
They can be made out of a lot of things but most are copper, Teflon or tin.
Jan 10, 2013 | Home
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
Good luck.
Jun 12, 2011 | Microwave Ovens
Can i refurbish my non stick pan. Some of my friends used a knife and made some nasty marks. can i get this fixed
At best you can recycle. Once the skin of the coating is compromised, there is little or nothing you can do to re-coat the surface with a coating such as the factory coating.
I use pans with compromised seals as a double boiler when making candles. I put my wax pot in the frying pan, fill with water, then melt my wax. I do not care of the pan gets wax on it because I no longer use it for cooking.
I also use larger frying pans pans with compromised seals under the car when I drain oil. I allow the oil to drip (provided it is less than 4 qts.) into a plastic milk container that I cut the top off of. I set the plastic container into a large frying pan that I no longer use. The handel on the pan makes it easy to slide out the plastic container once it is full of oil. I then take a funnel and transfer the oil into another milk jug or old 164 oz laundry detergent bottle that still has the threads for the plastic cover in tact. I mark it used oil and set it aside in the corner of the garage for when our community allows for the annual oil and chemical waste pick up.
My dad was an avid hunter...he used old frying pans for target practice when on the country land...he'd hang pans from the handel and shoot at the pans he hung.
Sorry this is the best I could do.
Being a mom that has gone though this enough times....I removed all my metal utensils from the drawer next to the stove with plastic ones hoping my kids would grab the closest which are now plastic that is heat tolerant.
Mar 20, 2011 | Microwave Ovens
I have had this pan for about 1 1/2 yr. , being retired I only use it once every 2 months or less. i know less than 10 times. It has alwys heated extremly hot ( only use 250degress or less) . Last time I...
I really don't think there is much you can do. You could ask a kitchen utensil distributor if they have a contact to have the pan re-coated for you, otherwise remove the rest of the coating and use it as a conventional pan.
Feb 02, 2011 | Rival S160
I have a black sticky residue on the non stick surface of my cooks essentials 12 inch frying pan. I can not clean it off and the non stick properties of the pan is gone, I think due to this surface...
Go to epinions.com, type your product and find you are not alone. Besides, as there is no cure to baldness there is no such thing as a perennial non stick pan. All coatings invented eventually succumbs to the wear and tear produced by temperature changes, contact with food and related chemistry, detergents, scrapping, etc. Consider the possibility that some of that non stick material may be ingested unconsciously.
Dec 18, 2010 | Microwave Ovens
Home Logo
340 people viewed this question
Top BALLARINI COOKWARE Home Experts
john h
Tom Chichester
Are you a BALLARINI COOKWARE Home Expert? Answer questions, earn points and help others
