Question about Toshiba E-studio 230 Copier W/net Print, Scan, E-file
When turned on, All I get is a "splash screen", A pixelated image of the control panel on the left and an image of the copier on the right.
Can't get past thei "splash screen" I can get to the diagnostic screen....
    New Friend:
I'm having the same thing with mine, i just bought it off ebay, it's frustrating, have you figured it out?
Posted on Nov 25, 2013
My laptop screen has a thin blue line going down, why has this happened?
You have the beginning of a failing Display panel, and will eventually need to replace the display.. you can hold the top left and right sides of the display screen-slightly bend forward and back, you should see the blue line either go away or it will produce more lines...
This is due to a short on the circuit board panel on the backside of the display panel that controls the Pixels on the Screen.. The Pixels are controlled In a Line Grid Fashion...
Nov 16, 2009 | Dell Inspiron E1505 Notebook
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PowerShot A480 Digital Camera
The images are way to big on my computer screen
right click on the desktop > select > properties > in the display properties > click the settings tab > move the resolution selector to a lower resolution > click apply.
if it is better click the yes to keep the setting
Oct 14, 2009 | Dell Latitude D505 Notebook
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
My LCD TV Has 4 large round black spots (50mm diam) on the left side of the screen. I accidentally splashes a little water on the unit the day before, but in the bottom (right) corner only. It is a Teac...
The dots cannot be rectified, static dots of this kind on an LCD panel are dead pixels or liquid cristal leaks, depending on their hape and aspect.
The only fix is by replacing the LCD panel, that is an expensive part and must be ordered by phone, as it is not normally in stock.
You can inquire by phone here to find out part price.
Mar 28, 2009 | Samsung LN52A650A LCD TV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Changeing resolution
On the back of the camera, push "Menu."
A menu screen comes up.
The first option is the one you're looking for:
"Image Size."
UNDER that option, the first sub-option is "8 M," the next is "3:2," the next is "5 M" and so on. That "M" is "Mega Pixels, or "million pixels." The size of the file will be measured in megapixels, and each "pixel" requires 3 Bytes of memory to define it. (A "pixel" is like one tile in a mosaic tile image.)
You change the options and sub-options in the menu by using the round donut-shaped control on the camera back. On the outside of the "donut" there are arrowheads pointing Up, Down, Left and Right. When you push the donut in the spot next to an arrowhead, you go whichever way the arrowhead points. Up goes through the MAIN options, right/left takes you through the SUB-options under the main option.
Change from a lower file size to a higher one by going left and right through the "Image Size" sub-menu. The biggest file size is "8 M" and I suspect the smallest is at the extreme opposite side of the list.
Someone apparently set your camera, maybe before you bought it, to a file size that is as small as possible, so you could fit the maximum number of pictures in the camera. But to get a better image for printing, you need to change to something with more pixels!
Apr 23, 2008 | Sony Cybershot DSC-H3 Digital Camera
Image is grany every time tv is cold.
I had the same problem. Except mine never got better after the tv warmed up. I fortunately I still have my manufacturers warranty and Samsung sent a guy out within a few days. He replaced a few parts which really didn't do anything. However what he did that was interesting was on two circuit boards. One on the mid left and the other on the mid right. Apparently there is a nob or something he tweaked on each panel that cleared the grainy image right up. What he told me was that the it is basically pixels that are not turning off in sync. adjusting the two circuit boards syncs the pixels to turn on and off at the same time.
Nov 02, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Toshiba E-studio 230 Copier W/net Print, Scan, E-file Logo
37 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
