Question about Hardware & Accessories
Timer does not stay on time - Hardware & Accessories
  • 5,245 Answers
Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Buy another timer.
Add a comment and describe timer in detail.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 19, 2013
My timer goes on at the set time but stays on all night instead of torning off at the set time. What can I do?
Following link has troubleshoot steps for wide variety of timers:
Timer might be set wrong or be defective
Gene
Water Heater Timers Save Money
Feb 26, 2015 | Hardware & Accessories
Bass pro turkey fryer wont stay lit
wire around timer or set something on button so runs all time. but also set a cheap alarm or use one on cell phone to remind you time is up.
Feb 25, 2012 | Bass Pro Steamer/Fryer Combos Turkey Fryer
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I put the timer on my lamp and it stays on even if it's not the time that I set, and then it turns off when the time is up... Why does it stay on? And not go according to the timer?
For digital timer:
1) Timer is defective
2) Conflicting programming so timer does not perform as expected
3) Timer not set to correct mode.
4) Program 'off' is set correctly, but program 'on' is not set or 'on' time conflicts with other programming.
5) Current time not set correctly
6) Polarity on outlet is reversed or noise on the line. Check outlet with circuit analyzer.
7) Combination of factors listed above
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Jun 26, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
I cannot set my GE timer--15119----I have no instructions and have tried many times---I can't believe how difficult this timer is to set----
Here's what I found.
Pull up all of the little pins around the dial.
Push down all pins for the time that you want the light to stay on.
Leave pins up for all time that you want the light to stay off.
Rotate the dial to the current time of day.
Plug timer into wall.
Plug light into timer.
Ensure light is ON.
Gary
Feb 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
HB51R is "on" all the time, regardless of control setting kenlarson42@hotmail.com
HB51 appears to be an automatic timer
Capacity is 1000Watts
Your lights are on so the circuit has power
I don't see any troubleshooting steps
It gives you a choice how many hours your lights stay on after dusk
You might try changing the selector to a different stay-on hour.
Turn timer off and unplug and then re-plug timer to see if it re-sets.
Otherwise, it looks like the photocell or 'timer brain' stopped functioning.
Oct 23, 2010 | Intermatic Outdoor Timer/Photo Control...
Lights stay on
manually turn the dial pass the red pointer. that shoudl shut-off the light.
if not, you have a defective timer.
if it does. follow the instruction set the gree pointer for the time to turn-on and set the red pointer to the time off.
turn the dial one or more revolution till the arrow head in the center align with the time of day in the center windows.
Dec 30, 2008 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
47 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
